There are no Anduril lights that run on AA, they ones that exist only use LiIon.
Anduril lights have both regulated output (regulated up to 120 lumens on the FW3a), and direct drive for highter lumen levels.
Anduril lights also change brightness in response to thermal regulation, also depending on how many lumens you ask for. (anything over 500 lumens will not be sustainable, and thermal regulation will kick in to limit output and heat, iirc)
Right but this entire thread is about development of a driver that would accept both 14500 and AA. It would indeed be a first, and that’s why there are questions about its capabilities.
that is not my impression
every time the AA portion of the conversation surfaces, I find it is set aside in favor of LiIon only
IF this thread produces an AA capable Anduril light, I will be interested, but so far, I have not seen any indication of that happening. I hope it does.
You seem very deeply interested and yet also highly cynical about this project, jon_slider. You could always hire an electrical engineer and have them build a board perfectly to your specifications.
I second that. I’d like to see a 1.5/4.2v capable driver for AA/14500 and Andruil. The electrics needed for that are complex though and I get it if they don’t want to redesign a board from the ground up to make that happen. That adds cost and complexity. It’s just so easy to do 4.2v only and call it good. Plus higher performance. Most of us would use it with lithium ion anyway.
This post has been around the block about 30 times. Just make the damn 14500 version and we can have it in a few weeks- according to Barry it won’t take long. I’ll buy several on the spot if so. Besides, just like those who went from D cells to 18650s, there are the “hanger-on’ers”… the AA crowd who can stick to their guns for another six months until MAYBE they can figure a 1.2V version of Anduril into this thing. But the SC31 Pro is proving the small Anduril light is in demand… and it’s just a matter of WHO will do it first in the 14500 form factor.
I’m not saying there aren’t any, but all the dual-fuel lights I know have screwed-up mode-spacing for one chemistry vs another.
Eg, my Xeno E03 has kinda nice spacing with alkaleak/NiMH, low is actually low, and high is just meh, but spacing is rather nice. With Li-ion, everything’s just brighter. Flick through H/M/L, and it’s like 100%/80%/60%, everything just pushed higher.
Low-volt chemistry needs a boost converter to feed the LED, but with Li-ion it’s linear or a buck converter. So scaling/matching levels for both chemistries will almost always suck. At least PWMing either a FET or 7135s stays proportional, but that does not translate well to a different controller (ie, boost circuit) running in parallel.
I expressed interest in this about a month ago. Since then the SC31 Pro has been released. I very nearly ordered one, but I’m going to wait to see if other emitters are offered. I mention this here because the recent discussion has been about the necessity of AA Anduril support. I hope this (AA support) happens and I hope it isn’t just an afterthought on a 14500 driver, as Lightbringer implied could be the case. And as Zappaman eluded to, scaling Anduril to a smaller LiIon form factor isn’t groundbreaking, shouldn’t be all that difficult, and I think will happen sooner or later (and, to be fair, he did say he’d buy several).
But having a tiny flashlight with tons of features that runs on boring old AA (or, imagine, AAA!) single battery, that would be unexpected and novel.
From my perspective I can put this a different way:
SP10S BLF Anduril 14500, I may buy one for myself because it’s small and special.
SP10S BLF Anduril AA (and 14500), I may buy one for each of my family members, friends, friend’s children, etc. with no concern about needing to educate them regarding loose LiIon handling / care. And definitely buy one for me.
And I ordered three, have two, and I’m waiting on # three with the 5k emitter. But the price is a bit steep compared to the SC31B and for the few extra bucks I’ll be buying IF25a’s for a Sofirn EDC type light with Anduril.
But… I’ll NOT be buying them if the cost of developing a good cross/chemical driver takes the price much more than a few bucks over the standard model.
Again, novel new designs are cool and I’ll support them to a degree, but when they make no sense to manufacture given the market’s price expectations, Sofirn maybe can’t do both AA and Anduril given the extra cost of doing so maybe can’t be recovered in the marketplace.
And… as we near 500 posts on this topic, perhaps the writing is on the wall already.
Wubens E05 is an exception. Modes are the same, just turbo is missing when running AA/NiMH. There’s at least another one but I don’t remember which one it was.
Sure it’s a nice small light,
I hope the design will be correct, smoother without sharp edges and pineapple knurling
would be more elegant and pleasant to handle.
Same thing for the others tube style models.
The Manker E11 doesn’t suffer from those mode spacing differences, but on AA alkalines or Ni-MH it will surely drop in output on the higher levels.
I am still in for when this project sees the daylight
Meanwhile I may try to mode one of my SP10 lights to take an Anduril driver, if I make the mod well
I would buy several even if it is only for AA (alkaline or NiMH).
If it was only 14500, I didn’t buy any, not even for myself, because it is almost impossible for any seller to send li-ion to my country. And if they are obtained in my country, they are of poor quality and are very old.
At this point it should make sense just to release the li ion version while they continue to do with the AA version.
Whats the minimum run 1000’s pieces? How many runs would sell out before the AA version is ready?
