Hi.
Somebody asked if you plan to make a power load but you didn’t say anything !
where ? we have a plan , but it will be a long time
I already have some of your power suppply.
But I was wondering about electronic programmable power load, not USB tester.
edit : sorry I made confusion from your signature as an answer !
thank you so much for your long time support
I know the electronic programmable power load, not usb load, we have plan for this , it should be after this year
Hi RD Tech
I just bought the new RD6012W and the wifi does not work with OnePlus 5T or iPhone 11 Pro max.
However, its does work with old Samsung A3(2017) phone.
I have a BT SmartHub router with both 2.4Ghz and 5Ghz radio on. And yes I made sure the phones where connected to the 2.4Ghz network
when trying to connect.
Is it anything to do with 11ac wifi band? Can anyone help?
Thanks
I have a OnePlus 5T phone with Android 9 and I cannot connect via Wifi and RDPower app.
However I did manage to connect with old Samsung A3(2017)
Hi everyone. Here is the link to a video of my problem
https://drive.google.com/file/d/1put5ecMHqB5ITJFsf-yrmzDRbaN87mVb/view?usp=sharing
Any help will be greatly appreciated,
Shaz
I have replyed you at email , if your Samsung A3 phone can work , our products and your operation should be not problem
so now the problem is your one plus phone phone and network problem
now use second phone hot spot as router to test again , if it can connect , it should be your network problem , please close your 5G to check
can the PC software also connect via the wifi module (or is it usb-port only)?
