good list, almost all are more than one LED but there are a couple,
here is one in AA/14500:
but it is NOT an Anduril version
YLP Unicorn 1.0. Not anduril, but very usable.
Thanks i forgot about that one but i’m starting to find tail switch awkward.
Also don’t like the switch issues with that model
let us know what you end up with after digging through the list that 0oklight posted above
off the top of my head,
I cant think of any sideswitch anduril lights that are not multi LED
another factor to decide is what battery size you are shopping for
as an alternative
here is a very cool light with a Ramping UI
… not as complex as Anduril
pic is a link to more detailed info
Sofirn SC31 pro 5000K
jon_slider - thanks for that link btw. Looks good and I didn’t know about it. Mmm… Might have to acquire.
Fantastic,there are other models side/rear click with simple Smooth ramping UI and sublumen with 18650 extension tube that you know?
The Jetbeam RRT01 2020 version which has 2 extension tubes to be used with 18500 and 18650 cells. You won’t probably find a smoothest ramping than on that rotary magnetic ring flashlight!
Oh yes, look very interest but I search side/rear click,also native support 18350/18650 would be better
+11 though no 4kK option
MascaratumB:The Jetbeam RRT01 2020 version which has 2 extension tubes to be used with 18500 and 18650 cells. You won’t probably find a smoothest ramping than on that rotary magnetic ring flashlight!
the light MascaratumB just told you about does all those things, native 18350, and with extensions also uses 18650, and it does have a tailswitch.
Nothing out there, sc31 pro close (i own one already) but the 4k temp is top of the list as all of my lights are 5k+
I’m leaning toward the sofirn if25a 4k for 30$ next while i wait for something slender 4k anduril. sp10s hopefully will run sst20 4k
Sp10s is not an anduril light
Consider getting whatever host you prefer, and having the LED changed…
none of the lights I use have the original LED the host came with:
Yes i meant once its finally released (other thread on here)
I didn’t want to get into led swapping as i already have so many hobby related gear that sits around.
Maybe a convoy s2 would hold me over, is there a high cri =<4k with ui shortcuts to moon and high?
Any other brands would be ok 30$ or less
jon_slider:Sp10s is not an anduril light
I didn’t want to get into led swapping as i already have so many hobby related gear that sits around.Maybe a convoy s2 would hold me over, is there a high cri =<4k with ui shortcuts to moon and high?
You can’t really have shortcuts on a mech switch light. You can set it to turn on in moon and switch to high in 2/3 taps of the switch with several of the mode group options however.
Hi Jp9mm. If you’d consider an angle light, The Astrolux HL01 is a single emitter with Anduril. A little on the heavy side though.
Sari33: MascaratumB:The Jetbeam RRT01 2020 version which has 2 extension tubes to be used with 18500 and 18650 cells. You won’t probably find a smoothest ramping than on that rotary magnetic ring flashlight!
Yes sure nice light thanks.But I don’t mean rotary control,just by switch
You could contact Hank at intl-outdoor.com and ask if he can sell you a D4 with a single XP-L HI 5D emitter, as per the KR1.
click
ramping
sublumen
18650
if you cannot get everything in one light what will you choose?
EX11.2 ?
or
2020 RRT-01 ?
or
FW1a ?
the lowest mode on my D4V2 (3000K SST-20) I measure at 0.16 lumen
