Don’t worry. AFAIK, the next batch of C01R is scheduled already. The only difference is that they now use Luminus SST20-DR (660nm) instead of Cree XP-E2 photo red (660nm). Since the TIR optic works great with SST20 4.000K 95CRI (see beam of C01S) I expect a visible improvement in the deep red beam as well.
C01 using a 5mm 670nm LED will probably be a nice add-on / alternative to those who want to explore the lower end of brightness with deep red light. Using the original driver, I suppose its maximum output is not much more than 1lm (taking into account that Yuji BC made 8lm max). Maybe they can tweak the output a little bit but please keep in mind that deep red LEDs are significantly less bright than white ones.
I don’t know what UI Sofirn will be using on C01 with 670nm deep red but I wouldn’t be surprised if it comes with the original 2-mode UI (hopefully Low - High). My recommendation would be a two mode UI (Low/High) with 0.2lm for low and 1lm for high.
Should I get the chance to testing the new versions (Sophia 3.400K and 670nm deep red), I will take and post some beamshots / whitewallshots in comparison to all the other versions (C01 Yuji BC ww/cw, C01S, C01R).
The original C01 has a single mode, like the similar Fenix E01. The new version will almost certainly be the same. I don’t know if multiple modes is possible without a new driver.
It's most probably quite a challenge to get the differences of the beam and brightness (XP-E2 PR vs. SST20-DR) made visible on a picture taken by a camera but I was told it should be definitely visible to the naked eye. Anyway, if I get the opportunity I will try my best to highlight the differences (provided there are some) between both emitters, using my camera on long exposure with both C01R lights on ultra-low brightness.
Apologies if this has been stated before. I searched the thread and found info about lego-ing the original C01 with the Fenix E01. But has anyone tried to lego the C01 and the C01S? Or do we know for certain that the (new / upcoming) C01 and current C01S would go together?
If they do go together, I think I might order several so I can have different body tube colors. Has anyone tried?
I hope nobody minds doubleposting here. I have also posted this in the C01R thread but one of these lights will have a 5mm LED, so it might be interesting here as well.
Barry was so kind to send me a quick whitewall-shot from his smartphone camera.
From left to right...
Sofirn C01 5mm 670nm (prototype)
Sofirn C01R SST20-DR 660nm (prototype)
Sofirn C01R XP-E2 PR 660nm (series version)
Comments based upon some feedback from Barry:
actual perception of deep red color is more intense than indicated here
C01R SST20-DR is quite similar in maximum brightness - although actual brightness may differ but needs to be measured using a lux meter
hotspot beam shape/profile of C01R SST20-DR is yet to be reviewed in detail as any artifacts cannot be assessed on that picture - for now it looks quite similar to XP-E2 PR
production of C01 using the 670nm 5mm emitter may be revoked as the beam shows significant distortions - final decision is not made yet
After using the C01R for a couple of weeks, I understand what many others have mentioned: with completely dark-adjusted eyes, the Low of the C01R is still quite bright. The High seems like it could do some serious damage with fully wide open pupils.
Since Sofirn has committed to another batch of the (relatively) high-powered C01R, I wonder if they’d consider salvaging the 5mm Red as a one-mode sub-lumen light and include a diffuser with each. Then, the beam pattern wouldn’t matter at all - even more so if they can find a pebbled optic, too. With this kind of change the C01 5mm Red and C01R wouldn’t compete with each other for sales, either. The niche here is not as a novelty toy, but seriously targeting the astrophotography groups that want an extremely low light that won’t singe your eyeballs if you accidentally look directly at it.
Our latest product C01, using Sophia lamp beads, 3400K CRI 95+ 5mm LED. We have prepared 5000pcs emitter, expected to arrive at next week , Black, Blue, Orange, Green, Desert Tan each color 1K. In addition, there are 1K red , using 670nm red emitter.
