Thanks RapidLux.
Will be any difference in lumens between culpm1 and cslpm1 at 3A current?
Not appreciably. The main advantage (still theoretical right now as it hasn’t been tested AFIK) is a higher peak current before its thermally bottlenecked. In other words, other than binning differences, CULPM1 will be about the same as CSLPM1 until current exceeds ~5-6A. And in a flashlight with other thermal limitations, maybe less of a difference will be seen. TBD with time
Whoops, just not used to typing out the model number of the 4040 version now that they’re available!
Hello Simon,
Can you get Osram KY CSLNM1.FY (yellow) emitters?
I would be very interested in a thrower flashlight fitted with that particular emitter, if you can source them.
Probably I would take a Convoy M21A, but if you can fit it into a Convoy L21A, that would be even better.
[Deleted]
It is a buck constant current drive,
Simon Mao: BLF-L: BurningPlayd0h:Anyone have a rough idea what kind of cd we can expect from the S21B with CSLPM1?
Is S21B also available with CSLPM1? I can only see it with CULPM1 :
I can create a temporary link according to your needs,
Thanks Simon. I think I’ll wait for the new upgraded version of M3.
btw, what is the name of this new M3? Is it M3A? or M3C-U ?
Beside that, I’m still waiting for my SST40 S2+ , I’ll be checking it first and see how much I’ll like the 5000K SST40.
Maybe M3-C, C means “type-c”.
Hello Simon,
I will try to order,
It would be nice to see M31C, 21700 size
Hi cri throwers
What centering ring did you use?
i’m ready to launch a M21C-U with type-c port
Stock, supplied with flashlight
Would you reprogramm ramping UI to be faster from MID to HIGH and a little bit slower from LOW to MID?
It’s hard to adjust low/mid output correctly and over mid it looks like raming is not moving, until i see double blink as max value.
S21B CULPM1 at 9A? Let’s do this.
Hi cri throwers
what led is?
what led is?
Rgwn’s GT-FC40
See Maukka's report on 4000k here: https://budgetlightforum.com/t/-/58200/155 The 4000k is still in stock, here's final pricing (all transfer fees included) Item Cost: $12.6 $11.0 (effective december 2020 onwards) Shipping: Refer to this thread instead: https://budgetlightforum.com/t/-/58510 Pay: https://paypal.me/rngwn --------------------------------------------------------------------------------------------------------------------------------------------------------- Followi…
BLF-L:Thanks Simon. I think I’ll wait for the new upgraded version of M3.
btw, what is the name of this new M3? Is it M3A? or M3C-U ?Maybe M3-C, C means “type-c”.
id30209:It would be nice to see M31C, 21700 size
More flashlights with USB-C , that’s great !
My previous order is still on its way, but I’m really considering this M3-C , and grey S21B. This forum has made me buying too many flashlights lately
I really hope M3-C will be available in grey body color
