[Deleted]
It is a buck constant current drive,
Simon Mao: BLF-L: BurningPlayd0h:Anyone have a rough idea what kind of cd we can expect from the S21B with CSLPM1?
Is S21B also available with CSLPM1? I can only see it with CULPM1 :
I can create a temporary link according to your needs,
Thanks Simon. I think I’ll wait for the new upgraded version of M3.
btw, what is the name of this new M3? Is it M3A? or M3C-U ?
Beside that, I’m still waiting for my SST40 S2+ , I’ll be checking it first and see how much I’ll like the 5000K SST40.
Maybe M3-C, C means “type-c”.
Hello Simon,
Can you get Osram KY CSLNM1.FY (yellow) emitters?
I would be very interested in a thrower flashlight fitted with that particular emitter, if you can source them.
Probably I would take a Convoy M21A, but if you can fit it into a Convoy L21A, that would be even better.
I will try to order,
It would be nice to see M31C, 21700 size
Hi cri throwers
What centering ring did you use?
i’m ready to launch a M21C-U with type-c port
Stock, supplied with flashlight
Would you reprogramm ramping UI to be faster from MID to HIGH and a little bit slower from LOW to MID?
It’s hard to adjust low/mid output correctly and over mid it looks like raming is not moving, until i see double blink as max value.
S21B CULPM1 at 9A? Let’s do this.
Hi cri throwers
what led is?
what led is?
Rgwn’s GT-FC40
See Maukka's report on 4000k here: https://budgetlightforum.com/t/-/58200/155 The 4000k is still in stock, here's final pricing (all transfer fees included) Item Cost: $12.6 $11.0 (effective december 2020 onwards) Shipping: Refer to this thread instead: https://budgetlightforum.com/t/-/58510 Pay: https://paypal.me/rngwn --------------------------------------------------------------------------------------------------------------------------------------------------------- Followi…
BLF-L:Thanks Simon. I think I’ll wait for the new upgraded version of M3.
btw, what is the name of this new M3? Is it M3A? or M3C-U ?Maybe M3-C, C means “type-c”.
id30209:It would be nice to see M31C, 21700 size
More flashlights with USB-C , that’s great !
My previous order is still on its way, but I’m really considering this M3-C , and grey S21B. This forum has made me buying too many flashlights lately
I really hope M3-C will be available in grey body color
contactcr:What centering ring did you use?
Hey, stop holding out on me. Give full details! This is a 6V driver presumably and 12V LED. Also, did you need to make changes to the gasket?
Sorry my man, busy af. Driver is Convoy XHP35, emitter is Rgwn’s GT-FC40 which is 7070 12V footprint but R9080 and rated to 40W (yes, still no proper 3-4ABoost drivers :(...).
Since it’s 7070, stock gasket and reflector is simply perfect fit. So you just need to install Simon’s 12V driver which is the same size as stock M21C driver and swap emitters.
That’s it. The most beautifull build so far. This emitter is simply amazing
Left-GT/FC40 ~4500K 90+CRI, OP reflector
Right-Stock XHP70.2 5000K, SMO reflector
Wow, that is one amazing shot, it says it all !
Any link to a datasheet of the LED?
Wow, that is one amazing shot, it says it all ! Any link to a datasheet of the LED?
