The Jetbeam RRT01 2020 version which has 2 extension tubes to be used with 18500 and 18650 cells. You won’t probably find a smoothest ramping than on that rotary magnetic ring flashlight!
Nothing out there, sc31 pro close (i own one already) but the 4k temp is top of the list as all of my lights are 5k+
I’m leaning toward the sofirn if25a 4k for 30$ next while i wait for something slender 4k anduril. sp10s hopefully will run sst20 4k
Yes i meant once its finally released (other thread on here)
I didn’t want to get into led swapping as i already have so many hobby related gear that sits around.
Maybe a convoy s2 would hold me over, is there a high cri =<4k with ui shortcuts to moon and high?
Any other brands would be ok 30$ or less
You can’t really have shortcuts on a mech switch light. You can set it to turn on in moon and switch to high in 2/3 taps of the switch with several of the mode group options however.
Optic compartment is sized for a quad optic. I think they’re something like 8mm tall. The optic compartment too short to use an emitter properly sized for a single-emitter.
And there’s no point in using the quad star with quad optic and just one emitter installed. Sure it would work, but it would be inferior in every way to a D4 with all 4 emitters installed.
If your goal is a single-18650 light with sideswitch, single-emitter and Anduril, your best bet is to probably obtain a side-switch light of your choice and mod or replace the driver.
