2.5A with temperature control right?
zeremefico:People complaint for accidentally mode group change with 10 clicks
Special need people maybe?
Sure. I’m one of them. My special need is keeping crap out of the way that I don’t need more than once or twice ever.
Complications are always an option like masochism :)))
08CivicSi:any updates on CSLNM1.23 driver?
Yes, it’s in production now.
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
5.strobe-100%20 clicks to select group.
How do you think this mode?
I think it is very good. I would only change the order to a more sensible one. And I would add a 50% mode, which will not significantly affect the brightness and increase the working time.
1. 50%
2. 100%
3. 20–100
4. 100–20
5. 100%-strobe
6. strobe-100%
20 clicks is very nice. Memory no needed.
Please add temp control.
Left-GT/FC40 ~4500K 90+CRI, OP reflector
Right-Stock XHP70.2 5000K, SMO reflector
It seems to me that Convoy M3 can also turn out interestingly. Or even Convoy S11, but the reflector will need to be modified.
JaredM:Sure. I’m one of them. My special need is keeping crap out of the way that I don’t need more than once or twice ever.
Complications are always an option like masochism :laughing:)
20 is better than 10 if you use it and need it to be Tactical… even the GuppyDrv3 Tactical Mode with Lock Out takes 10-11-10 but the first 10 puts you in the “blink phase” for mode group “select”… it should have been more… IMHO…
Only if Simon make 12V e-switch driver then you could run it (FC40) in M3.
Not sure what emitter opening is in S11
SOS 9 clicks what if you press 1 extra and get stuck in 10% mode and starve to death on your island.
Does 2.5A driver really need temperature control that everyone complained about?
Temp control is always a good option. It’s better to have and don’t need than don’t have and need. Useful in small hosts. Maybe I would like to use this drivers for the s2? Not necessarily with osram. C8 with a green osram from Simon (2.8A) is hard to hold after 15 minutes.
Sweet Jesus, 9 clicks for SOS? 20 for thumb excercise...?
I guess i’ll stick to the whitey then LOOOL
stephenk:Gray Convoy S2+ with samsung LH351D ,Ra>90,DTP copper board ,ar-coated glass lens - is there any chance of having either 2700k or 3500k versions?
I will try to order it.
That would be excellent!
Sweet Jesus, 9 clicks for SOS? 20 for thumb excercise…?
I meant … —- …
Manual SOS, duh
I meant … — … Manual SOS, duh
Ahahahahahahahaha
I better stick to the beers, outgunned totally.
BTW have you seen post about new gen S2+ that have changed threads?
Cannot find it now but guys are complaining that 18350 tubes cannot be installed on other S2+ tailes and heads...
About a month ago I got a couple remote switches for S2. They wouldn’t thread on any of my existing S2 Simon said there was a bad batch with wrong threads and refunded. Then I ordered three sst20 x6 biscotti. I asked for short tubes instead of large tubes as I have a pile of extra large tubes, but short 18350 tubes (ideally uniquely colored so I can keep track of led/drivers) and a magnnet are what I usually use on these. He didn’t send the short tubes like he has in the past. So I try to put …
^ thread in question
Convoy S2+ - thread is different now
Thanks for your info.
Every S2+ owner (especially one who owns old S2+ and has plans to purchase new S2) should read that thread about S2’s threads .
Hopefully Simon will have some explanations here.
I love LEGO’ing my S2+ , so this situation is kind of unfortunate, it’ll be good to have clear information from Simon, which production batch has new threads and whether any further changes on the latest batch …
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
perfect. cant wait to get one
I don’t have any plans to get anymore S2+s so I’m fine, but I know it will affect others.
Although I do plan on getting a brass 18350 tube
Simon Mao: 08CivicSi:any updates on CSLNM1.23 driver?
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
yes ,2.5A
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
1. 50%
2. 100%
3. 20–100
4. 100–20
5. 100%-strobe
6. strobe-100%20 clicks is very nice. Memory no needed.
yes, temp control inside by default
Hi Simon,
1- Any news or plans regarding the new L21A with CULPM1.TG & 8A driver? ,
2- What was your thoughts since the last experiment? were you satisfied with it, or need to enhance it ?
3- Have you done more experiments with it after the one you told us about ? if so, what was the outcome ?
any ETA ?
