It seems to me that Convoy M3 can also turn out interestingly. Or even Convoy S11, but the reflector will need to be modified.
20 is better than 10 if you use it and need it to be Tactical… even the GuppyDrv3 Tactical Mode with Lock Out takes 10-11-10 but the first 10 puts you in the “blink phase” for mode group “select”… it should have been more… IMHO…
Only if Simon make 12V e-switch driver then you could run it (FC40) in M3.
Not sure what emitter opening is in S11
SOS 9 clicks what if you press 1 extra and get stuck in 10% mode and starve to death on your island.
Does 2.5A driver really need temperature control that everyone complained about?
Temp control is always a good option. It’s better to have and don’t need than don’t have and need. Useful in small hosts. Maybe I would like to use this drivers for the s2? Not necessarily with osram. C8 with a green osram from Simon (2.8A) is hard to hold after 15 minutes.
Sweet Jesus, 9 clicks for SOS? 20 for thumb excercise...?
I guess i’ll stick to the whitey then LOOOL
stephenk:Gray Convoy S2+ with samsung LH351D ,Ra>90,DTP copper board ,ar-coated glass lens - is there any chance of having either 2700k or 3500k versions?
I will try to order it.
That would be excellent!
Sweet Jesus, 9 clicks for SOS? 20 for thumb excercise…?
I meant … —- …
Manual SOS, duh
I meant … — … Manual SOS, duh
Ahahahahahahahaha
I better stick to the beers, outgunned totally.
BTW have you seen post about new gen S2+ that have changed threads?
Cannot find it now but guys are complaining that 18350 tubes cannot be installed on other S2+ tailes and heads...
About a month ago I got a couple remote switches for S2. They wouldn’t thread on any of my existing S2 Simon said there was a bad batch with wrong threads and refunded. Then I ordered three sst20 x6 biscotti. I asked for short tubes instead of large tubes as I have a pile of extra large tubes, but short 18350 tubes (ideally uniquely colored so I can keep track of led/drivers) and a magnnet are what I usually use on these. He didn’t send the short tubes like he has in the past. So I try to put …
^ thread in question
Convoy S2+ - thread is different now
Thanks for your info.
Every S2+ owner (especially one who owns old S2+ and has plans to purchase new S2) should read that thread about S2’s threads .
Hopefully Simon will have some explanations here.
I love LEGO’ing my S2+ , so this situation is kind of unfortunate, it’ll be good to have clear information from Simon, which production batch has new threads and whether any further changes on the latest batch …
08CivicSi:any updates on CSLNM1.23 driver?
Yes, it’s in production now.
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
5.strobe-100%20 clicks to select group.
How do you think this mode?
perfect. cant wait to get one
I don’t have any plans to get anymore S2+s so I’m fine, but I know it will affect others.
Although I do plan on getting a brass 18350 tube
Simon Mao: 08CivicSi:any updates on CSLNM1.23 driver?
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
2.5A with temperature control right?
yes ,2.5A
5 groups ,no memory
- 100%
2.100–20
3.100%-strobe
4.20–100
I think it is very good. I would only change the order to a more sensible one. And I would add a 50% mode, which will not significantly affect the brightness and increase the working time.
1. 50%
2. 100%
3. 20–100
4. 100–20
5. 100%-strobe
6. strobe-100%20 clicks is very nice. Memory no needed.
Please add temp control.
yes, temp control inside by default
Hi Simon,
1- Any news or plans regarding the new L21A with CULPM1.TG & 8A driver? ,
2- What was your thoughts since the last experiment? were you satisfied with it, or need to enhance it ?
3- Have you done more experiments with it after the one you told us about ? if so, what was the outcome ?
any ETA ?
Are there any plans for a 4x Nichia E21A flashlight from Convoy?
Hi Simon,
1- Any news or plans regarding the new L21A with CULPM1.TG & 8A driver? ,2- What was your thoughts since the last experiment? were you satisfied with it, or need to enhance it ?
any ETA ?
1.driver is in production now
2.uh ,what experiment?do you mena L21A with KW CULPM1.TG? it can reach 1190meters.I am satisfied with this range.
3…
1.driver is in production now 2.uh ,what experiment?do you mena L21A with KW CULPM1.TG? it can reach 1190meters.I am satisfied with this range. 3…
Okey, Nice,
When are you going to list it on your store ?
Hey Simon, or anyone who can answer - does the 5A SST-40 driver have LVP as well?
I’m assuming it does but there’s no mention of it on the product page.
