ZILZAL
(ZILZAL)
September 20, 2020, 3:59am
3399
Hi Simon,
1- Any news or plans regarding the new L21A with CULPM1.TG & 8A driver? ,
2- What was your thoughts since the last experiment? were you satisfied with it, or need to enhance it ?
3- Have you done more experiments with it after the one you told us about ? if so, what was the outcome ?
any ETA ?
stephenk
(stephenk)
September 20, 2020, 9:36am
3400
Are there any plans for a 4x Nichia E21A flashlight from Convoy?
Simon_Mao
(Simon Mao)
September 20, 2020, 2:06pm
3401
ZILZAL:
Hi Simon,
any ETA ?
1.driver is in production now
2.uh ,what experiment?do you mena L21A with KW CULPM1.TG? it can reach 1190meters.I am satisfied with this range.
3…
ZILZAL
(ZILZAL)
September 20, 2020, 5:19pm
3402
Okey, Nice,
When are you going to list it on your store ?
DarkShot
(DarkShot)
September 20, 2020, 5:24pm
3403
Hey Simon, or anyone who can answer - does the 5A SST-40 driver have LVP as well?
I’m assuming it does but there’s no mention of it on the product page.
Simon_Mao
(Simon Mao)
September 21, 2020, 12:17am
3405
DarkShot:
Yes.This is a standard function. I ignored it when I wrote the description. This is my mistake.
sochi111
(sochi111)
September 21, 2020, 3:56am
3406
id30209:
Ahahahahahahahaha
I better stick to the beers, outgunned totally.
BTW have you seen post about new gen S2+ that have changed threads?
Cannot find it now but guys are complaining that 18350 tubes cannot be installed on other S2+ tailes and heads…
The grey ones really suck, can’t recognize which one is new or old batch.
The color ones are still old batch I think,
About a month ago I got a couple remote switches for S2. They wouldn’t thread on any of my existing S2
Simon said there was a bad batch with wrong threads and refunded.
Then I ordered three sst20 x6 biscotti. I asked for short tubes instead of large tubes as I have a pile of extra large tubes, but short 18350 tubes (ideally uniquely colored so I can keep track of led/drivers) and a magnnet are what I usually use on these. He didn’t send the short tubes like he has in the past. So I try to put …
Simon_Mao
(Simon Mao)
September 21, 2020, 10:16am
3407
sochi111:
id30209:
Ahahahahahahahaha
Convoy S2+ - thread is different now
The old thread is a trapezoidal thread, the new thread is a rectangular thread,
Tangra
(Tangra)
September 21, 2020, 1:55pm
3408
New driver spring of S21A is ridiculous high.
No chance to use flashlight with 21700.
Even flat top18650 is 1mm over tube.
Simon, there is a growing selection of drivers and LEDs in your store. Could you divide the “LED, Driver” subcategory into two separate ones? “LED” and “Drivers” separately. It’s getting harder and harder to find anything.
id30209
(id30209)
September 21, 2020, 5:25pm
3410
Spring is fine, bypassed. And damping is perfect in case of drop there won’t be mode change. I have Molicel P42A and it works great
Tangra
(Tangra)
September 21, 2020, 5:59pm
3411
New one doesn’t have bypass.
For me S12 has perfect size battery tube for 21700. S21A is short.
id30209
(id30209)
September 21, 2020, 6:05pm
3412
If it’s not bypassed it means Simon built it with phosphorous bronze spring, not regular bypassed IMO
Simon_Mao
(Simon Mao)
September 21, 2020, 11:51pm
3413
Okay, I have re-completed the grouping,
However, the page display is somewhat delayed,
d_t_a
(d_t_a)
September 22, 2020, 2:28am
3414
probably the latest type.
Below I pictured some revisions of S2+ SST40 4-mode driver.
top pic shows the earlier SST40 4-mode driver (softer spring with spring-bypass wire pre-installed) ; driver spring is "triangle" shape. ; tailcap current measures (to verify again... something like 4.5+ Amps I think)
middle pic shows a fairly recent SST40 4-mode driver (a bit stiffer spring, not factory bypassed) ; driver spring is "cylindrical" shape ; tailcap current measures around 4.45 Amps
bottom pic shows a new SST40 4-mode driver (even stiffer spring, not factory bypassed), driver spring is sort of "trapezoid" shape, tailcap current measures around 4.8 Amps
bottom pic also shows the new S2+ body screw thread -- it will not "lego" with the 2 top S2+ body tubes. (the earlier shade of grey is also slightly diffferent (earlier S2+ gray is like a shade of bluish-gray, compared to slightly darker grey in newer S2+)
caramba
(caramba)
September 22, 2020, 6:13am
3415
How much interest would Simon need to get this High CRI emitter in a M21C, M26C and M21C-U with Ramping?
Sari33
(Sari33)
September 22, 2020, 6:16am
3416
d_t_a:
top pic shows the earlier SST40 4-mode driver (softer spring with spring-bypass wire pre-installed) ; driver spring is “triangle” shape. ; tailcap current measures (to verify again… something like 4.5+ Amps I think)
middle pic shows a fairly recent SST40 4-mode driver (a bit stiffer spring, not factory bypassed) ; driver spring is “cylindrical” shape ; tailcap current measures around 4.45 Amps
bottom pic shows a new SST40 4-mode driver (even stiffer spring, not factory bypassed), driver spring is sort of “trapezoid” shape, tailcap current measures around 4.8 Amps
bottom pic also shows the new S2+ body screw thread — it will not “lego” with the 2 top S2+ body tubes. (the earlier shade of grey is also slightly diffferent (earlier S2+ gray is like a shade of bluish-gray, compared to slightly darker grey in newer S2+)
Seem that spring on bottom pic have larger basis and driver bigger positive area than spring on middle S2+.
Their heigh is same?
caramba
(caramba)
September 22, 2020, 6:24am
3417
I see a new M21C in Simon’s store
M21C CSLPM1.TG 6500K
Are there any measurements available?
Tangra
(Tangra)
September 22, 2020, 8:44am
3418
Battery is standard 21700 flat top Samsung 40T.
This is not normal. I think, battery should be equal with tube.
Now S21A is perfect for 18650 battery.
