Does Simon have a website or do I need an elite BLF handshake code to contact him?
Wow… with a GT90 the government will be calling you to help with search and rescue missions!
Driver is just a standard replacement for my current one that struggles on high voltage + low power. Going to try flash latest firmware first.
I have a Cu Pineapple coming Soon™ and a D4SV2 and KR1 W2 on order (+ driver + flash kit). I’m pretty much sold on the idea of a EC10 in green so if liteshop still has one in a couple of weeks I will be playing green light saber wars in June…. then it _may_be time to sell or gift a couple of lights, hah!
Hey Aussies, any tips on high drain 26650 For d4sv2? I know supersports600 has keepower 26650 which is a good all rounder but their MNKE IMR look pretty angry at 20a/60a. Any else I should look at while I struggle over the amps vs mAh equilibrium lol?
I’ve got a coupla boosted C8 Driver/led inserts in mail.
One here. one in Cyberspace.
Also a Sofurn SD03.
One of the nicest looking/feeling torches I have.
It not working on arrival. grrr. and no stock left to replace.
It’s a shame they stopped prod, of such a nicely built torch.
Anybody here. In Qld preferably. That works on heads.
Copper board. Drivers?. Led to suit.
Not wanting a burner. just a good reliable working wet use light.
For boat and fishing. It’ll be a shame to throw away $27AUD.
I’ve got soldering iron etc. but very heavy handed and near blind for close work nowadays.
(Wrong side of 78yrs). OK with a welder and dragline though…
Regards
Macka.
I was thinking upgrading the head lights on my ride on mower or doing lights under the coffee table or on a timer in the chicken pen to regulate their daytime hrs during winter and lay more…
I recently set up a new garage door light; the roller door motor light is weak as hell and doesn’t illuminate anything, so I got a 12V3A power pack, into a 12V photo sensor relay, then out to a 36V1A buck regulator, and out to 2x 36v Cree COBs on old CPU heat sinks. In parallel to that buck, out to a 5V3A stepdown to a laser pointer in a line, to line up on my steering wheel when I’m parked in the right spot
Hey lads if you are after something cheap and cheerful check out the Coleman Divide +250 on a Amazon for around $8. Its a great light, well built and comes with batteries its a little on the bigger side but it should be able to with stand a beating if you give it to the kids. Its only got two modes so it should be easy for any one to use. They state 250 lumens but its brighter than that.
Best way I found was to get the 4x MCPCB from intl outdoor with them, and reflow to remove. Doesn’t give many options, but it’s the cheapest way I found. $16.50USD for four, but then there’s postage (unless you buy a bunch and get free shipping).
Only has 6500K and 5000K at the moment.
But actually in Aus, cutter are about the only people with them.
This place is good too - they sell Samsung, Sony/ Murato, Molicel, Tesla etc. in mainly 18650 and 21700. Prices generally seem good compared to other options. https://www.tinkertechau.com.au/
