Can you point me to exact point in video (minutes). Was to lazy to watch the whole bla bla
I would say to start on 2m30 till 3m20, where he presents the specs.
I was listening again and guess I may have misunderstood his words, when he was presenting the “stepdowns”.
His words are “Now, that is thermally regulated, so depending on how hot the light actually gets, that’s how fast it will start to drop down”.
Checked. He dows say “depends how hot it gets it will stepdown” BUT packaging cleay shows 4min on 1500lm then stepdown AFTER 4 min to 500lm for 200min...
I think presenter is not familiar with these words and terms and the mean.
But Martin, again, can confirm this 100%
Martin...?
Checked. He dows say “depends how hot it gets it will stepdown” BUT packaging cleay shows 4min on 1500lm then stepdown AFTER 4 min to 500lm for 200min…
But Martin, again, can confirm this 100%Martin…?
Yeah, that was what I noticed on my second “hearing/seeing” on the video. So now the doubt has increased in me.
So…MARTIIIIIIIN
Maybe with M1R (announced at US FB group) might get my attention but this one for sure will not.
Link?
Damn those runtimes are crazy good for an 18650. One of the most efficient 18650 lights I’ve ever seen. Olight really makes the most efficient drivers in the industry. But unfortunately Olight is too stubborn to provide neutral white and high cri options with “good tint” (non green). I’m probably going to skip this despite the amazing performance and aesthetics.
Does anyone know what emitter they use?
I still think Zebralight is nr.1 then Olight.
That info is absent from the manual :zipper_mouth_face: I really have no clue, but…maybe it is an SST-40 after seeing the image after the destruction test:
Minute 7:49
which video are you guys reffering to?
i did not show my measurements for the Warrior Mini ???
Damn those runtimes are crazy good for an 18650. One of the most efficient 18650 lights I’ve ever seen. Olight really makes the most efficient drivers in the industry. But unfortunately Olight is too stubborn to provide neutral white and high cri options with “good tint” (non green). I’m probably going to skip this despite the amazing performance and aesthetics. Does anyone know what emitter they use?
its an SST40 LED ;)
530 Lumen for 3:20 hours
170 for another hour
then faded down to 6 Lumen and LVP kicked in after 5:45 total time
OP by Olightworld.
Does it have temp or time stepdown?
Link?
Post deleted !
It was mentioned by one of “Olights”. Looks like he got his fingers slamed and now his post is gone.
Can’t copy-paste link but look for Scott Jay Marshal II poll about M1R.
as far as i know and tested all Olights have a timed stepdown, but you can reactivate turbo as long as the cell voltage allows and the over temperature protection does not kick in
the guy in the OP video is not correct with "1500 for 4 minutes and then lower to 500"
i had max 45 °C and 1:40 mins to drop under 1500 (max was 1650)
level @531 reached after 4:30
Yeah, ZL still beat the crap out of Olight. Ugly as hell but way better electronics.
I think my new Warrior Mini will be SC600Fd :)
Martin, thank you so much for the information about this light!
I am still thinking of it due to the dual swiches and UI, as I’ve been looking for a light like this for a while (smaller than the M2R and similar features).
Will you have any deal for it or the current Olight deal is the best one currently?
ZL beat the crap out of Olight in terms of emitter selection but Olight is miles ahead of Zebralight in terms of driver efficiency. The Olight H2R with 4000K XHP50.2 70 CRI has an efficiency of 135lm/w where as the Zebralight H600fc MKIV w/ 4000K XHP50.2 90CRI only makes 89lm/w. The difference in efficiency between the two emitters is 20% max, so Olight is obviously much more efficient. Also the more recent Olight Perun with the XHP50.2 can do “*500 lumens for 4 HOURS!! Olight is king of driver efficiency.
The thing ZL drivers are really good at is the ultra low moonlight modes that can last an eternity, which is great if you ever get trapped in a cave.
Just briefly tested one H600Fc Mk4 sample, thanks Kaybi. Just like on most frosted ZL’s, output is quite far from specified (1124 lumens measured @30s vs. 1568 advertised). The tint is great with little difference between modes. Tint shift is a non issue thanks to the diffused lens. Efficacy is mediocre. CRI and tint data measured from the hotspot on max mode (H1). Very nice tint (duv 0.0011) at 3983 K. [image] CRI data on M1. Slightly warmer and farther away from BBL but still great (duv 0.…
EDIT: W Mini is something special, design and look is something we haven’t seen in flashlight world
those sales are not beatable
(using my links but help me quite a bit ;) )
Olight does not offer HI CRI emitter options. But the comparison above is to show the difference in electrical efficiency between Zebralight and Olight drivers. Both use 4000K XHP50.2. The Zebralight 90CRI is at max 20% less efficient than the 4000K XHP50.2 in the H2R. So if you do the math to account for the CRI difference, (135lm/w) / (1.20 * 89lm/w) = 26.4% more efficient. But the more recent Olight Perun, which is an upgrade of the H2R can do a whopping 500lumens for 4hrs, which is MUCH more efficient than the H2R and is MUCH MUCH more efficient than Zebralight.
But as I mentioned in multiple posts above, I do not disagree with you Olight sucks when it comes to CCT, CRI, and tint, which is what is preventing me from buying many of their otherwise attractive lights.
EDIT: go get it boys!
