So what is your point—only the elders die, we should just let them die, they are old anyway?
And those aren’t infection survival rates—that is dishonest on your part; the data in the report are estimated fatality rates used for Scenario 5 of the CDC planning document, and are based upon a research paper by Hauser et al. using data from Europe.
Why do they not just publish and use the actual data from the USA fatalities, wouldn’t that be more realistic than using adjusted age range data from 6 EU countries. They don’t have nearly the same number of fatalities even if you add them all together—the USA is number 1 by a big margin.
BTW, he study focus on 6 regions of Europe and not 6 European countries (EU would be only for the European Union).
Quoting the article:
It is uncomparable what happened and what is going on here (Europe) and what is going on in these countries (both due the total population, the total infected, and the total deaths:
Did I say he did?
He works under the NIH, at NIAID, just as the CDC does.
You don’t think any data from the NIAID, was used by the CDC, for that report?
Do you question the credibility of the CDC, the NIAID, or every department under the NIH?
Or do you question the credibility of all of them, under the HHS?
Yet another person trying to instigate an argument by misrepresenting information, then accusing others of doing the same by correcting the misrepresentations. Bravo.
It’s already been explained that the figures given were estimates, based on various assumptions, from early numbers tabulated in one investigation in Europe. The authors state clearly that those numbers do not represent the expected effects of the virus, in Europe or elsewhere.
“How is that a misrepresentation, when it is data DIRECTLY from the report?“
The answer to your question has been given to you by two different members. I’ll try one more time. You said the figures you cited are the survival rates from the virus. That is in fact not true. We explained why it is not true in our posts.
Is 71k5 trying to make a point with those figures? Perhaps the point is just information? Is the point supposed to be that it is not very deadly for the young? I think that is the point but I don’t know.
Just looking at the numbers. From what I have read eventually about 80% will likely become infected unless there is an effective and widely adapted vaccine. So only .02% or .8 * 0.0002 * 20 - 49 year olds will die. It looks like the point is that because only 20,000 or so Americans between 20 - 49 will die so that is not really such a big deal?
