Did I say he did?
He works under the NIH, at NIAID, just as the CDC does.
You don’t think any data from the NIAID, was used by the CDC, for that report?
Do you question the credibility of the CDC, the NIAID, or every department under the NIH?
Or do you question the credibility of all of them, under the HHS?
Yet another person trying to instigate an argument by misrepresenting information, then accusing others of doing the same by correcting the misrepresentations. Bravo.
It’s already been explained that the figures given were estimates, based on various assumptions, from early numbers tabulated in one investigation in Europe. The authors state clearly that those numbers do not represent the expected effects of the virus, in Europe or elsewhere.
“How is that a misrepresentation, when it is data DIRECTLY from the report?“
The answer to your question has been given to you by two different members. I’ll try one more time. You said the figures you cited are the survival rates from the virus. That is in fact not true. We explained why it is not true in our posts.
Is 71k5 trying to make a point with those figures? Perhaps the point is just information? Is the point supposed to be that it is not very deadly for the young? I think that is the point but I don’t know.
Just looking at the numbers. From what I have read eventually about 80% will likely become infected unless there is an effective and widely adapted vaccine. So only .02% or .8 * 0.0002 * 20 - 49 year olds will die. It looks like the point is that because only 20,000 or so Americans between 20 - 49 will die so that is not really such a big deal?
I just provided the link to the report data, and pointed out the Fatality data, and stated the resulting Survivor rates from their own Infected Fatality ratio data.
Because if you’re not a fatality, you obviously must be a survivor.
You draw your own conclusions, and dispute the CDC data, that’s your prerogative.
If the Infected Fatality Ratio is 1: .054, that would mean 5.4 out of 100 infected 70+ would die, from being infected with the virus. So that would also mean that the other 94.6 70+ who were also infected, did not die.
Hence a 94.6% survivor rate for 70+ infected with the virus.
