Those 219b emitters don’t like being driven too hard. I actually kept my max ceiling set low as they will overheat and actually put out a purple tint that won’t go away when over driven.
I hate to be the bearer of bad news but the damage may have already been done. It happened to mine initially as well.
they should not “overheat”, are you sure it’s not just the anduril blink telling you it’s at the top of the ramp? I dont remember if the stock E07 firmware has that or not
You should probably clean everything with alcohol (springs, threads, driver ring, and your battery + and -)
If you are using 18650 make sure to use flat top with their black adapter. If you are using 21700 make sure it is flat top and not too long (Chinese brand battery sometimes are while OEM brand is shorter)
If you can use turbo for much longer than that, the turbo isn’t high enough IMO!
I can turn it down myself (with the button or with the software) if I want a longer running level of brightness. Turbo is for momentary use…that’s literally the whole point of having a turbo. Like nitrous on a vehicle. Use it too much and it’ll probably blow up, but it’s there for short bursts when you really need it. :sunglasses:
I was happy until it broke - switch doesn’t register clicks. I’ve contacted the company about the issue. They asked me to provide video evidence, which I did and then I got ignored. Not recommended.
Just go buy Emisar/Noctigon from Hank. I’m sure you’ll be more satisfied in the long run.
the same happened with the switch in my pl47. If you remove the rubber of the switch, you will probably find a small, round and thin golden plate that is loose
