You should probably clean everything with alcohol (springs, threads, driver ring, and your battery + and -)
If you are using 18650 make sure to use flat top with their black adapter. If you are using 21700 make sure it is flat top and not too long (Chinese brand battery sometimes are while OEM brand is shorter)
If you can use turbo for much longer than that, the turbo isn’t high enough IMO!
I can turn it down myself (with the button or with the software) if I want a longer running level of brightness. Turbo is for momentary use…that’s literally the whole point of having a turbo. Like nitrous on a vehicle. Use it too much and it’ll probably blow up, but it’s there for short bursts when you really need it. :sunglasses:
I was happy until it broke - switch doesn’t register clicks. I’ve contacted the company about the issue. They asked me to provide video evidence, which I did and then I got ignored. Not recommended.
Just go buy Emisar/Noctigon from Hank. I’m sure you’ll be more satisfied in the long run.
the same happened with the switch in my pl47. If you remove the rubber of the switch, you will probably find a small, round and thin golden plate that is loose
Just wait a while. Jack is real busy and doesn’t check messages and emails for days or even weeks at a time. I’m guessing he is focused on the new lights right now. But he will surely get back to you.
Jack had over a dozen “defective” lights shipped to me to check. More than half of the lights were fine and I couldn’t reproduce the claimed issues. I suggested to him from then on that he should request customers to show videos of the defect before allowing a return. I’m glad he listened. Business is hard for small businesses when people treat returns like it’s Costco.
