I made an order on 14/05/2020. Still not shipped(
This one might fit after filing it to length on the led end, 57.8mm(D) x 55mm(H) SMO Aluminum Reflector
http://kaidomain.com/ Product Code : S021807
Or maybe this one.
.ALSO
12.78€ 5% OFF|60mm(D) x 50mm(H) SMO / OP Aluminium Reflektor für Cree XM L / XHP LED|Tragbare Beleuchtung Zubehör| - AliExpress*
Thanks for the suggestions CNCman. The K6 reflector is designed to fit inside the host with its particular geometry, so fitting any other thing inside requires careful selection.
Given the situation, I am @#$%. Can't help feeling like @#$% the whole thing altogether now. I wish I could re - coat the reflector easily. Jeez with this now.
New Arrivals :
Cree XHP35 HI A4 27G Warm White 2700K CRI90 LED Emitter
Cree XHP35 HI A4 30G Warm White 3000K CRI90 LED Emitter
Perfect for an emitter swap for my MF02 and BLF GT.
Hello Ban,
These new XHP35 HI batches are really nice additions. I have seen 40G 90CRI and 2B 80CRI already, but if you could get a 90CRI batch of them with one of these tint codes, that would be even better:
one of 4A, 4B, 3C, 3D, or one of 45G or 50G. These would be around 4500-5000K, and would make a super nice neutral white thrower.
Could you please consider it?
+1^^^^
I made an order yesterday with the previous coupon code : sum (–10% off), try this one instead of mid.
BanL, I highly recommend you buy one of the following to test your LEDs so you know what you actually bought and if your suppliers are being honest with their labeled bins. Also if you can label your LEDs with the CCT, CRI, and tint (DUV), it would greatly help your customers buy with confidence and this will set your store apart from other LED stores online. Keep in mind many customers might not want to take gambles when buying emitters.
HPCS300 Mini $499 (No screen)
https://www.aliexpress.com/item/10000168095794.html?spm=a2g0o.store_home.productList_597510024.subject_3
OHSP350 $649
https://www.aliexpress.com/item/10000021726931.html?spm=2114.12010612.8148356.8.f9847abd10qFCE
OHS350C ($779 same as above but with software to produce reports on computer)
https://www.aliexpress.com/item/10000110079556.html?spm=a2g0o.store_home.productList_597510024.subject_1
I’m sure if you contact the company directly on their website, you can get some discounts.
+1000
I don’t buy emitters these days until they are proven by somebody here with at least a beamshot comparison. And I only but more than a sample emitter until I’ve tested it or someone posts spectral data. I can’t deal with much more than 0.0010 duv. Lee filters have saved many LEDs from the trash bin, but they’re not ideal. They scratch easily and cut a lot of lumens. This really should be a standard practice for any seller who claims a specific tint/CRI binning.
I too was intrigued and purchased one a few days ago. My intention to put in a White Flat 2mm^2 and Convoy SST40 driver (Link). Added a note regarding SMO reflector, hope they oblige.
“sum” works fine.
Thanks!!
Is KD operating normally at the moment? I have three orders on “processed”, the oldest one for more than a month. Nothing shipped apparently and I don’t get replies to my emails either.
Just right now, I bet not because from October 1st to 7th (or 8th), it’s the golden week = China’s national holiday.
I placed two orders around Sept 10 and 17 and received them around Sept 25 and on Oct 2.
Even the website has holiday feelings. It’s down today.
And down again today.
I made an order (bare emitters (in stock)) on 1st Oct and shipped on 9th, so even with website down, things seem to resume pretty normally after the golden week/national holiday.
@BanL
Is this emitter available or not?
http://kaidomain.com/Cree-XHP35-HI-Neutral-White-4000K-CRI90-LED-Emitter
Once placed in the cart it says it's out of stock but on the product page says different.
Hello Ban,
Same for me, I did also put it in the cart, but before checkout, even for one piece, the site showed a warning, that the quantity I need cannot be provided.
If this LED has been already sold out, then could you please get XHP35 HI C2 45G 4500K CRI90 for us? (If that is not possible, I will also buy 50G or 40G, but 45G would be the best, once you have new stock of this LED)
