Ya so sweet… I ordered the 4300K a few hours ago from Neal along with all the accessories and chose the fastest shipping. Gotta take stock of my batteries - needed some new 18350s for my Noctigon KR4 2000K that’s coming (:
What an addictive hobby huh? I never thought when I was a kid that there’d be devices like this. Can you imagine what they’ll have on another 10, 20 or 30 years?
Make sure your cells are short. Even 30q cells with very small button tops are very tight nearly unusable. Flattops I believe are recommended. The light has the throw of the blf gt but with 4 times the lumens. All that in a much smaller light. But be safe, this needs treated like the hotwires of old. I would be careful of temperature shock and the lens. Also be careful where you put the light when putting it away, don’t put it right in your coat pocket because it will melt your clothes or burn you. But have fun because it is insanely powerful.
Wow, I can’t wait to get this thing. What cells would you recommend? Max power is all I care about. Run time is not an issue because I’m going to keep extras when I’m out
Hello, the battery life of 8 batteries is about 100 minutes, which is more convenient to use. The battery is built-in and can’t be taken out. Due to the battery logistics delivery is very troublesome, many logistics companies do not mail, so the sale of foreign countries is suspended. thank you
Hello, FF5 battery is four batteries in series, the battery terminal power is about 120W, FF5 start speed is fast, so the starting current is large, FF5 needs to use flat 18650 power battery without protection, there is no need to worry about battery over discharge, because there is a protection circuit inside the FF5 battery rack. thank you
Hello, the HID flashlight needs 4300k. 4300k has strong penetration. It is more suitable for use in rainy and foggy weather. In addition, the luminous efficiency of 4300k is also higher
I want a lemax bighead lx70 but I cant really justify it so I have been looking at how to put a bigger reflector on the FF5 or 4. I can probably buy the genuine head but with the reflectors I have built I am wondering how do I grind a compound reflector. The ff5 reflector looks to be the same curve as the ff4. So from the specs I could find out of curiosity plotted the curve I would like to have a reflector with the same geometry. FF6 with 6inch head??
In reality the Sony can hold higher discharge for longer, but is temperature limited. Realistically they are both 15A cells and only the Sony can do 20-25A for short periods (up to 70 or 80C), but reduces its lifespan. Unless you need that extra ‘oomph’ from the battery you’re fine with 30Q. They are a bit cheaper.
Thank you my friend. I just ordered 10 of the 30Q’s from Illumn and 4 18350’s for the KR4 and some other lights that use them I have some other lights that take 18650’s and it will be good to have some extras around and I wanted to get to the $75 free shipping
Hello, 4300k has high luminous efficiency and strong penetration in rainy and foggy weather. The other 8 battery rods are no longer sold abroad, because the logistics cost of built-in batteries is very high. Thank you
You’re going to be blown away by this light. As somebody that has the previous models, they really did it right with this one. The FF3 was a true pocket rocket with simple on off interface and a thermal stepdown. I like the knurling style styling the best with the tight knurling. The FF4 added the additional button to the side for mode switching. The smooth reflector and greater power made it a stand out and appeared to even best $2k Polarians in some of the shots I’ve seen. But the added turbo requires holding the button while it was in low. However you only got 3 min in turbo and once you got the stepdown or switched back to low or high, the light couldn’t be put back to turbo until it was power cycled. But with the FF5 you get a legit 10,000L thrower with 1.2 million lux. Plus the user interface is nearly as simple as the on/off of the FF3, with the side switch controlling h/l and the back being the power on/off. To really appreciate it, like any thrower, get out to an area where you can really stretch it’s legs an fire it up.
Haha dude I’m really excited. The only long distance thrower (if you could even call it that) is the Acebeam W30 which although cool, isn’t very useful for much of anything.
