Noctigons are tiny indeed but it is the reason I chose this combo. We need some space between LED and bezel and D4S (or even X6 w/ “Angie” spacer) is actually too big since Angie optic is ~35mm and mule MCPCB is only 24mm so we have plenty of space on sides. Height will be slim compared to some spacers but I dont see problem. Maybe you cant countersink a anti-rotation hole but everything else seems ok
Yes and xhp70 .2
Also xhp50.2, xp-l2, xp-g3, probably xm-l3 (it’s new led) too. They all have a terrible tint.
Hi, any chance you could make a Convoy C8 copper pill?
No, all Convoy C8s made last 5 years do not have pill.
I got mine this week as well, really good quality spacers! The craftmanship on them is incredible for the price, and they fit perfectly without any modifications in my S2+ triple. The thermal contact is really good as well when using quality thermal pastes, having no problem with overheating. I can only recommend them, and will probably buy more if needed.
Any idea if the triple spacers will fit the newer copper host I think it has slightly different threading
Dont see any reasons why they should not fit.
I have new copper host and “old” spacer. Working great :)
I ordered some parts a while back. They took a long time to arrive due to customs. Parts arrived well, wrapped individually and thoroughly. The manufacturing is clearly at a high level. Thanks a lot!
I would like to order 3x L21A spacers. What’s the thickness on these? 5mm?
L21A? Sorry, don’t have any spacers for this model.
I think he meant S21A
Yes S21A, sorry for the confusion!
S21A spacers in stock. Plane to plane distance is close to 5.5mm.
Fits 20mm mcpcb correct?
If so I’ll take 3, I’m building a couple quads with a 22mm optic, measurements say I need a 5mm spacer so I’m sure it will work.
any spacers for new convoy s21b?
thanks.
No, I have not made any product for S21b.
Since it has no pill - spacer height tolerance should be more tight. I dont have this host so I can’t say if it can fit any existing spacer or not.
BTW, I can not ship anything to the UK until Royal post will accept international shipments.
thank you, and thanks for the shipping heads up .
