https://www.banggood.com/custlink/mDGyV3mi0m
XIAOMI sale on bangood
and new beamshots!
[Limited offer!] Sofirn IF25A , 3800 Lumen Anduril, with Rechargeable 21700 Battery
Sofirn IF25A Led Torch Super Bright 3800 Lumen Anduril UI SST20 LED Flashlight with Rechargeable 21700 Battery Super Bright and multiple use.
SEEKNITE C8+ SST40 2000LM Dual Group 5000K 18650 Flashlight
MANY COLORS ! Olight S1R Baton II 1000 Lumens CW with Battery, SKYBEN Battery Box Inculded
Seeknite sure looks to be copying some of Convoys designs.
i already try to find out if its a OEM brand or something similar
OEM product - but different UI and LEDs
The Seeknite ST03 picture looks exactly the same as a Manta Ray S21 flashlight that I’ve checked out, except different LED and UI.
I guess they all come from the same factory..
some are marked Convoy, some get another brand name
i ask
new review online!
www.youtube.com/embed/jLQF1ssqJG0
i showed the prototype a year ago ;)
i fixed the links
Also hadn’t noticed announcement of this model before.
It uses 3x XHP70.2 … so it would look like a competitor to the Haikelite MT03 TA Devourer, which also uses 3x XHP70.2, which also uses NarsilM and Texas Avenger driver. But maybe Lumintop’s build quality may be better? (MT03 TA Devourer claims “21000” lumens which is more of an exaggeration, whereas the GT3 specs indicate 18000 lumens, which might be possible in ideal conditions (high-drain battery + maybe if spring-bypass is needed?)
I wonder how the battery carrier tube looks like on the GT3?
So much mis/lack of information in the listing of the GT3 - says NarsilM, then says Anduril, says smooth reflector then shows an OP...
Would like to see the battery tube and if the button has a LED controlled by the firmware (EDC18's switch LED is not controllable by firmware).
That bunny button, if like the EDC18, could be stiff and prone to wearing down - not big issues, but they could have done better with the EDC18's button for sure.
