Me wanting uno
sent
‘Interface - Micro, Type-C, Listing’
Do they actually mean Lightning?
ps. Interested
Any clue if it charges long 21700 (the protected button top ones)?
75mm max length so most protected 21700 should fit.
Interested. Thanks!
Interested
got mine 3 item..Thank you Martin...
That makes sense. I was wondering why it looked like there was a second USB Type C input.
Also interested.
ordered one. many thanks M4DM4X!
Can you confirm cut-off voltage options please? Your specs only show 4.2V/1.48V, but BG also lists 3.65V. thanks!
where do you see 3.65V?
Was in the specs earlier today on Banggood. Looks like they updated it.
Interested
I’m interested. Thanks!
Interested
ps. Interested
Looks like there are quite a number of typos in the ad item description, the “Listing” (as you mentioned, it’s likely “Lightning”) typo also exists in several of the images.
Package includes a “manul” (manual).
End charge current: around 150mAh (around 150mA?) (150mA seems high if charging smaller batteries though)
Looks like an interesting charger, with triple input options (micro-USB, USB-C and Lightning). I would prefer an mAh display (charged capacity) rather than the “time” display though.
Hopefully BG can send a sample for HKJ to test (if HKJ has time to test…)
This seems to be the first “Astrolux” branded charger, hope they get it right. (Gearbest had the Zanflare C4 charger some time back — I guess “Zanflare” is a Gearbest brand or close affiiliate) Promo price of $11.99 looks reasonably good for this charger, plus it fits 75mm which is most protected 21700 batteries)
Count me in
Interested
Interested. Count me in
If it does not have a 3.65 volt cut-off voltage, what does this mean? If you put in a 3.6-3.7 volt battery (like the iJoy INR26650 4200mAh - 40A), might the battery get damaged?
