Looks like there are quite a number of typos in the ad item description, the “Listing” (as you mentioned, it’s likely “Lightning”) typo also exists in several of the images.
Package includes a “manul” (manual).
End charge current: around 150mAh (around 150mA?) (150mA seems high if charging smaller batteries though)
Looks like an interesting charger, with triple input options (micro-USB, USB-C and Lightning). I would prefer an mAh display (charged capacity) rather than the “time” display though.
Hopefully BG can send a sample for HKJ to test (if HKJ has time to test…)
This seems to be the first “Astrolux” branded charger, hope they get it right. (Gearbest had the Zanflare C4 charger some time back — I guess “Zanflare” is a Gearbest brand or close affiiliate) Promo price of $11.99 looks reasonably good for this charger, plus it fits 75mm which is most protected 21700 batteries)
If it does not have a 3.65 volt cut-off voltage, what does this mean? If you put in a 3.6-3.7 volt battery (like the iJoy INR26650 4200mAh - 40A), might the battery get damaged?
Most 3.6/3.7v li-ion batteries are defined to be fully-charged when they reach 4.20v.
From what I know, the iJoy INR26650 4200mAh is just a regular li-ion battery that is fully-charged when it reaches 4.20v.
(nominally “3.6/3.7v” are fully charged when they reach 4.20v
nominally “3.85v” batteries, sometimes called LiHV or Li-Ion high-voltage are defined as fully-charged when they reach 4.35v)
There’s another type of li-ion battery called the LiFePO4 that is nominally 3.2v (or 3.3v?) and defined as fully-charged when they reach 3.6v (but some reference may be 3.65 or 3.70v ? ).
This Astrolux VC04 appears to only support the 3.6/3.7v li-ion batteries (that fully-charge at 4.20v); based on specs, the VC04 can also charger NiMh batteries.
