You want something with two modes, a high and a low. They will set a hot light down and walk away or else not see something with “moonlight” and overdrain the cell. This is yet another reason why all lights need two switches, a separate one to control all modes.
Sadly, that’s why MLH-with-nomem is so popular with The Muggle. I got used to M on my (Xeno) E03, and rarely bap the switch for L or H, so I treat it like a 1-mode light. Also why I never got any otherwise nice-looking OnTheRoad lights.
Lights which default to H, eg, my big honkin’ Tacklife, heavily diffused, I also treat it like a 1-mode light, even when I don’t need full blast. I just can’t get all worked up to hit the switch a 2nd or 3rd time. :weary:
As for The Muggle, I’d also push the magring selector like the Sofirn diving lights, even though parasitic drain can kill the cell if not “maintained” by The Muggle, so for that I’d also have to DQ any light with too much parasitic drain.
The SP10 I gave to my gf, she “presets” to M or so, so that she can just click it on/off and have usable light that’s neither too dim nor too bright.
I think she’s okay with her Cometa, but forgot if I left memory on or turned it off.
With one major caveat, one of the best lights for The Muggle is probably this 4×AAA LuxPro light, heavily diffused. Really nice soft-touch tailswitch, driver-in-tail so it’s just one switch which will take you to your desired level within like 4 clicks. Defaults to H, so it’s as simple as click-on/click-off, only cycles if subsequent clicks are within N seconds of being turned on.
Would take a 21700, but I’d need to add a tall spring to the driver first. Protected cell with built-in usb charger would make it perfect for The Muggle without having to worry about an alkaleak crapping the bed in an impossible-to-get carrier.
If you configure the Hell out of it, the SC31pro would be great for The Muggle. Turn mem on/off, set manual mem, whatever it takes, to kinda dumb it down but still let it be used in non-lobotomised form.
In short, it’s not so simple. And that’s why 2×AA Maglites are still incredibly popular.
I gave two non-flashoholics FW21 Pro, that I purchased specially just for them, because they are very nice people and therefore, should own a very nice flashlight. This, so as to bring these nice people even more joy than they already have from life on earth.
But, I did not give them the hot little screaming pocket rockets, replete with Anduril, until after I spent a few hours educating them about all aspects of it. Now, they are new, budding flashoholics!
Boruit D-10 . King of the budget headlamps ... just like a old lumintop AAA Tool starts on a medium mode .
You're right in saying people want light right now .. but all muggle mode type lights are actively turning them down for them . So muggle start in med mode has to be a perfect answer .
Like every idiot here I hated the thought of a med low high mode order but after using it for years it makes perfect sense and like putting the toilet seat down .. after you get trained . It actually makes sense .
…until you get blinded in the middle of the night when you grab one that starts on M and not L (or F).
That’s why the only 2 I grab for at night are the ones with lit sideswitches, the GTmicro (level 1 for F) or the SC31pro (ditto), as I know press’n’hold starts at firefly levels.
If I grab the Xeno, even in WW, it’s “Aaaaaah! Bright lights! Bright lights!”. Forget about going back to sleep after a blast of that…
Father in law knows best. On and off are the only modes non-flashlight nerds want or need. The AAA Mini Mag LED and the Mag ML25 twistys are pretty simple and easy to use.
Again for Muggles all they want from a light is light . anything more is simply confusing . So you can start on a mode thats low and make them mad because it produces no light .. or a mode that has too much light and gets hot .. or you can screw with the high so it's no longer a high and try selling that magic . The d10 is a perfect example . you know what it's gonna do if you're a flash head . if your a muggle it gives what you'd expect or need .. If you're a flashamatic ya oughta know what the lights gonna do when you go click .
The bathroom light is a motion detection light . it's one of the best lights I own considering how much work it actually does vs those 800 sitting on shelves all competing for shelf queen glory .
The Miuja ? 4AA motion lights we bought on sale for like 8 bucks rock .. I have two and I wish I had 17.
the e03 xeno even on a AA has no low . it's a great host remarkable design and reallyreally BAD with a 14500 because now the low ..ain't low ..no mo .
I used a AAA tool Nichia as an EDC for years and M/L/H is perfect because 20-30 lumens of hi cri is damn delicious .(when you need a little light)..and if you know you want low you can click on and half click quicker than the time it takes for the electrons to begin to move ..It just takes talent
the 2xAAA nichia 219B smooth head off the iyp365 put onto a regular tool is the simplest answer to getting a real sub lumen low too .. not to mention the light feels better too .. looks better, feels better ,works better .
Right .. So you make one that turns on in a mode that a moron can't hurt themselves or anyone else with >> medium, and you don't totally hamstring a light for everyone else with their faculties . Something for grandpa to grow into after he's used the light for a year or more . That way it's a tool that actually works .. Not just a junker light . other people with their wits ca actually appreciate the extra modes . High first seems right but ...Why either let it get hot ... or make high at a level it doesn't .. both thoughts are flawed .
Wellp, the original (non-pro, non-B) SC31 was exactly that. High was 500lm and dropped down to 300lm or so after a few min. It was almost the definition of a gramma light. Couldn’t hurt yourself setting your pants or purse on fire if it accidentally got bumped on.
But I’m not sure if it sold all that well, being elbowed out by 9999999000lm “tactical” lights. Damned shame, ’cause it was almost perfect for The Muggle.
The ’pro is now 2000lm? Ouch. Gramma would set her house on fire.
Some one who is “ a brilliant and capable man. A professor of psychology, award winning ball player, and a capable handy man (runs tractors, chain saws, you name it)”
doesn’t sound like a moron, or someone who doesn’t have their wits about them to me. I have had similar experiences with smart and capable people who are not into flashlights that just don’t want to fool with modes - for them simple utility is best.
Well, if we are REALLY seriously talking about non-flashies, then certainly any Dollar Store 35-lumen “9-led flashlight” in cheesy colors and a packet of 10 for $2.99 would do. If we are talking about having a nice work light for someone who wants a light that can be used, with that someone wanting something better than a storebought light, then it’s as I said. ^
if i`m lending it and going to get it back before the battery needs charging then the Convoy M3 is good, 4 power levels and Off. if I`m gifting then I use old school flashlights (basic On/Off) modded with a protected 18650 and tripple led emitter, I ALWAYS supply them with a charger as well, and have a quick chat just so they understand what to do (it`s not rocket science) my 71 yr old mom picked it up pretty easy
I tend to agree with that, but that doesn’t rule out something extra.
Ideal would be, say, a 400lm light. That’s brighter than most ever seen or need.
No memory and it just always turns on at that level.
Unless they enter a hidden mode like long press for moonlight/turbo.
That way they have a simple on/off light with the potential of something extra.
NON flashaholics come in three flavors: (pre)adults, (small)children and senior citizens.
- If your question is about the first group, it’s just a matter of logic or preference.
- Don’t get me started about the middle group. Some can only poop, others can operate any flashlight.
My 3yr old neighbour kid instructs his mother how to install the kiddy-seat.
If his tiny hands were any bigger, he would do it himself. Silent type, boardroom or supermax material
Gave him a multi-mode flashlight on his 4th birthday. No need to tell him about hidden modes or so.
- Last group, and it’s getting bigger very day. A much heard slogan is: 60 is the new 40.
There are two groups of retired folks: those who finally do the things they always wanted.
And those who buy a big chair to watch the world go by. Behind a window or in front of a TV.
My late father started out in the first group, on a ladder, painting his house at the age of 75.
But like Robin Williams he was cought up by Lewy Body dementia.
It was quite a struggle to provide him with things that could made him live on in his own house
(losely monitore by friends and neighbours) until it was time to move him into a safe environment.
With that said, if you’re thinking about the last group, there’s only one thing I can recommend:
KEEP IT AS SIMPLE AS YOU CAN, so I second the advice of TexasToasted in post #10.
My (4*AA) SWM M40A comes very close to that, but it has a (lame) strobe that should be removed.
Bit of a ridiculous poll with only 2 choices. Essentially you have already chosen your own answer, all you are really asking is should it have memory or start in high - the 3 mode is the same on both.
Most people and I mean 99%+ of flash light users simply have on or off and are more than happy with that.
Most wouldn’t even realise it had 3 modes let alone memory or how to change modes.
People like us who fascinate about flashlights, tints, ui’s etc are essentially weirdos (me included lol), and a tiny tiny tiny spec of a minority.
So with that in mind none of your choices, certainly none with lithium batteries either.
Off/On (high) would be the best choice for the rest of the 99%+ of flash light users in the world, all they want is light to come out when they press the button, and wouldn’t want to fiddle through modes even if available.
