Hello everyone!
I have Nitecore MH20 with already changed main LED to XM-L2 2700K & led’s in switch button but…
I found new Nichia E21A and I fall in love with 3000K temperature color (CRI >= 98).
The main reason i write this post is nonstandard copper base plate.
In MH20 it’s look like:
I want to put four E21A led’s.
Nitecore driver gives 3V @ 3A current.
Is any mate here who be able to make custom copper or company where I can order one?
@uniti Virence.com Is not affiliated with the BLF user virencelights. The BLF user that runs Virence.com goes by the name Clemence.
@virencelights
Hey, I don’t know the history behind your username, but especially in the case where you reference Clemence’s store Virence, that is part of your username, it can be very misleading to other members and potential clients of Virence. Might be worth stating that you and Virence.com are not one and the same.
Quad e21a is wonderful. You should also consider quad e17a as well. Slightly less efficient, but more intensity. In either case, the gap between dies will mean you will likely have to diffuse the glass to get rid of the center donut. E17a quad will maintain better throw.
