I have a d4v2 2700k sst 20 and noticed the candle mode brightness is much lower than the e21a 2000k even after i lowered the floor is there anything i can do to make it as low as the sst20 2700k? Im talking about push push hold from off. I have reflashing kit if needed.
Once in candle mode you can change the brightness. Click hold for brighter, click click hold for dimmer
I did that already its still mich higher than the 2700k sst20 in brightness
How would you compare brightness of the lowest possible mode (not candle mode)?
Probably driver that you have in d4v2 e21a is 5A CC. In SST-20 - 7135+FET. They’re a bit different and the lowest modes could be not equal.
My second guess - I vaguely remember that candle mode algorithm has been updated in some version of Anduril. Do you know what version you have on each of your light?
On the lowest mode the e21a is actually dimmer. Im not sure about the version
