Hi Adam, my worry is that I took that pic at around 4m from the wall, and that at a longer range the corona will affect the hotspot (which is a nicely rounded one at that)!
I was going to buy a Wainlight C8+ to run as a comparison, but, they all look the same so to me I’m making an assumption (probably a wrong one) that they all have the same manufacturer, and are just rebranded!!
I’ll wait until dark and try it then, if I’m dissatisfied, it’ll be returned, simple.
Oh and the glass was a little dusty too, a resold return perhaps?
The corona is normal, the LED phosphor is not perfectly at the middle by itself if you look closely. I don’t have this green tint, maybe its a faulty LED or its a different tint. Are you sure its from the official Convoy store? There is many fake stores.
This C8+ with osram are not in use on small distances. But in long range are better than SST40 and XPL HI. Just it’s very little long range thrower. If you wanted near distance thrower you must get SST40 or XPL HI. They have no problem to be useful in distance bellow 50m.
Hi Degman, I’m a long range thrower type myself, I have a TN42 for the longer ranges but it’s a bit big, I have an FT03 (SST-40 W) too, which is my current ‘go to’ flashlight, I bought an E10 recently also, good but it’s not breaking any records, so that’s me EDC ‘close quarters’ tool. I wanted a small but big thrower………hence the C8+ purchase!!
Hello Omega, I think, only think, the green tint in the corona may actually come from A) the iPhone camera, and B) the actual wall!!!
I’m going up to a place in the hills (if it hasn’t been Corona-Closed) that has little or no light pollution, I take all my flashlights there, and I’ll see what’s what then!
Will keep you informed!
Regards
Rob
EDIT: I just ordered another C8+ from NealsGadgets!!! To run a comparison!
Stockton-Rob: any update on the Convoy C8+ with OSRAM?
I just got mine in from Simon’s store. When shining it at the wall in an apartment (maybe 2 meters away), the hotspot and corona appear to be overlapping. I can see the hotspot, but there’re three egg-shaped coronas on top of it.
Definition of hotspot and corona fromhere: Beam Anatomy
Any way to overcome this on my own, before sending the light back to China? I’ve tried to take out the reflector and centering ring, then putting it all back together. Same result.
I did exactly what you did, I unscrewed the reflector, removed it, use an air bulb lens cleaner to rid it of dust….then gently screwed it back together, pointing it vertically, until I got less of a corona, it was a pain in the butt to do, but I’m happier with it now.
I did however also buy a Manker U22-II, thinking it would out-throw my Convoy, they’re very similar, but the Convoy hotspot was better…oh and the Manker has corona too.
Egg shaped coronas, three of them, doesn’t seem right.
Try the vertical screw/unscrew method first, tilt the flashlight accordingly to the corona, if it forms on the left, tilt it to the right etc.
Hope this helps, if not, send it back as defective!!
That’s normal…the smaller the led, the harder it is to center perfectly, it’s extremely difficult and I build my own and struggle. The much more expensive Noctigon K1 has an off center led, but still performs well.
Did you buy it to shine at a wall? Does it affect your use outside?
If it’s badly off center then loosen the mcpcb screws and correct it by pushing it while tightening the screws.
We at blf asked Simon to use these leds…can’t then start complaining about this issue, it can’t be helped, especially at this price point
The egg shaped coronas are normal with this led, entirely different than the normal in your link
thanks for your reply. Will try bringing the Osram C8+ out at night to test.
Kinda lost touch with the flashlights scene. The only old throwers I’ve are the Jaxman M8 (XPL-HI) and the Convoy C8 (XM-L2). M8 looks ok, nice focused beam. The C8 has a similar bad corona, though the hotspot is bigger and less intense.
It’s just one of the downsides to having a tiny led in a reflector. I installed the same osram into the Convoy S2+ and it’s worse on a wall but performs nicely.
I had the opportunity to inspect renovation progress (new indoor office) earlier at sunset. First tried the 4x7135 S2+ (1.4A SST20). Too weak. Even the company-issued MTE flashlight (to a specific department, not me) is brighter.
Went back and grabbed the C8+ (4.8A, Osram KW CSLNM1.TG). I can now see from one end of the office to the other.
