groupbuy: Astrolux® AC04 LCD Display 1.5A AC/DC Quick Charger
Banggood reeased another model of their new chargers:
Astrolux® AC04
LCD Display 1.5A AC/DC Quick Charger Li-ion Ni-MH Battery
For 18650 26650 21700 AA AAA Battery
my code: MAAC4 your price: $16.99 US$24.99
please post below if you pull ther trigger!
Specification:
Brand
Astrolux®
Model
AC04
Charging interface
Built-in power AC power cord: 110-240V 50/60Hz 0.4A (Maz)
External power supply: DC12V 2A
Compatible Battery Types
1.2V NiMH/NiCd:AA / AAA / AAAA / C /SC
3.6V/3.7V/3.85V Li-ion/IMR/INR/ICR
3.2V LiFePO4 (max length 75cm): 10440/14500/14650/RCR16340/16650
/17500/17650/17670/18350/18490/18500/
18650,20700,21700,22700,26650,26700……
Charging cut-off voltage
4.20±0.05V/4.35±0.05V/3.65V±0.05V/1.48V±0.05V
Recharging current
500mA×4;800mA×4;1500mA×2
(1 channel and 4 channel Li-ion)
Charging cut-off current
<150mAh
Operating temperature
0-65℃
Charger size
165x 105x 38mm / 64.96x 41.34x 14.96inch
(Length x Width x Thickness)
Weight 350g
How to use function keys:
Press "SLOT" to switch to view the charging status of the 4 slots.
Short press "MODE" to switch to 500mA or 800mA. When 2 channels or 3 channels have no battery, 1 channel or 4 channels can be up to 1500mA (lithium battery).
Long press "MODE" to select battery type to charge: Li-ion4.20V; LiFePO4; Li-ion4.35V
LCD screen display function:
  1. The number indicates the corresponding channel data.
  2. The light will turn off after 30 seconds of work.
  3. Any button can wake up the light.
  4. The channel lights with full power will be on.
Package included:
1 x ASTROLUX AC04 Battery Charger(Not include battery)
1 x AC Power Cable (EU Plug)
1 x Plug Adapter according to your country socket
1 x User Manul
1 x Box
reserved
Looks similar to Miboxer C4?
This is better than the USB powered one…
More batt types… I.e. 3.85v and lifepo4
What I dont like is the charging current too low when using 4x batts (4*500mA)
I want the code for this one!!
in the text above - yellow background ;)
Ouch! Thanks!
Is a US plug version of this coming?
whats the difference between this and the VC04?
input
more chemistries
The listing indicates that it ships with an EU cord, but also includes an adapter for the buyer’s country.
The cord looks like a standard ‘figure eight’ power cord. You might have one lying around that you could use instead of the EU cord with US adapter.
Ordered, thanks! :smiley:
