It charges 2x faster than V3 per the info (3h40m). Comes with a bike mount in addition to what’s already included in V3. Slightly higher capacity battery and a much nicer looking charger.
Cree XHP50.2 LED with a lifespan of 50,000 hours
9 regulated light modes + 3 Strobe
Hot Spot: Spill: 70 °: 120 °
With 18650 3500mAh battery and before 10% drop from initial value
Turbo 3: 2500 (LED Lumens) (OTF Lumens) (2h40) (650 Lumens after 30 seconds) range 131 meters
Turbo 2: 1750 ANSI Lumens (2h45) (650 Lumens after 2 min)
Turbo 1: 870 ANSI Lumens (2h50) (650 Lumens after 9 min)
Main 3: 370 ANSI Lumens (5h15)
Main 2: 160 ANSI Lumens (12:15)
Main 1: 45 ANSI Lumens (43h)
Moonlight 3: 6 ANSI Lumens (12 days)
Moonlight 2: 1.5 ANSI Lumen (40 days)
Moonlight 1: 0.15 ANSI Lumen (200 days)
Strob 1: 10Hz at 2,500 Lumens (5:45) (650 Lumens after 100 seconds)
Strob 2: 1Hz at 2500 Lumens (12h) (650 Lumens after 9 minutes)
Strob 3: 1Hz at 160 Lumens (55h)
Battery: 1 x 18650 3500mAh battery (included)
Charging time: 3h 40 minutes
Made of aircraft grade aluminum alloy
Finish: Matte Black Color, Anti-scratch Hard Anodizing Type III 400HV
Operating temperature: –25 ° + 40 ° C
Dimension: 112mm (Length) x 33mm (head diameter) x 20.4mm (body diameter)
Weight: 65g (without battery and without headband) / 115g with battery
Waterproof according to the IP68 standard (10 meters for 5 hours)
Fall resistance 10 meters
10 year manufacturer warranty
Package contents:
Lamp Armytek Wizard (V4) C2 PRO
1 Armytek 18650 3500mAh battery
1 USB charging cable
1 Headband with rigid support
1 bike / MTB handlebar mount
1 belt clip
2 spare O-rings
They say one of the benefits of working with Armytek is high profit margins, “over 100%” on the last page of that manual. We should do a “group buy” and just bulk order a bunch at cost
Thanks for this useful information. Looking at your photos it looks as if new new design has a slightly longer tailcap (accounts for the increased length), different heat sinking, new button and a new font for graphics!
But the interesting thing is the bezel redesign - could you confirm that the inside diameter is larger, or is it the same?
DUV lower than V2 5D! Wow I wonder where they source all those rosy Cree emitters. I would love to buy just the emitters. Where did you buy yours from?
Thanks for confirming - I thought it looked larger. And as others have commented, news of the tint is interesting. My V3 Pro has IMHO a good tint, and I am now tempted by V4.
I like the sound of all these changes so far. In your other pictures it looks like it has a slightly larger button also.? Don’t know if I need “fire starter” mode but it can’t hurt much. I’ll only be tempted if it is at least as warm as the current “warm” and it sounds like the cri will be higher.
It looks like they slightly modified a Lumonite Compass R head. It already had a bigger bezel and button and spring in head. Armytek clearly makes the Lumonite L shaped lineup “from” Finland.
