These arenāt LED, but the old-timey hotwire bulbs. The 2AA are easy to match-mod, but the 3D is gonna be a beeyotch.
Pretty sure the reflector diameter is about the size as a Q8 reflector, so was going to try(!) to do something with that. Worst case I was gonna DD it from those 3 alkaleaks and maybe a small series resistor (questionable thermal path), and wire up a āconnectorā from a gutted PR-2 bulb for simplicity, vs having mag-guts all over and a nonworking light of any kind.
I ordered as well, twice after i canceled the stick on version and got the air vent one instead. TY OP
Hopefully this is the best version. A little confusing with the options but i believe they are total: Shape/mount/color
Iāve used similar ones in the past. The mount has a few neodymium magnets in it. You either adhere one of the included steel plates to your phone or slip it between your phone and a case. Then your phone will stick to the mount via magnetic force. Itās pretty nice.
I quit using them for now because I use wireless charging with my phone. The steel plate would usually block charging unless you position it just right (away from the coil in the phone) so I havenāt used mine in a while.
