ALL THINGS BUDGET KNIVES
The Bestech Engine looks similar to the EOS Prawn. I just got this one from Drop.com for $135. It’s nice, but the handle is just too short for me.
Oh yeah, forgot about that one. Thank you. I have a Bestech Pebble and it is a mighty fine knife. The Engine might be a better choice than the Prawn. At least the odds of it being good are better anyway. Put that on the list so I don’t forget it.
I’ve really been trying to slow down on my knife buying. I am not so much a collector so I feel guilty when a knife just sits around not getting used. My friends on the other hand love it when I get to feeling that way because I start giving them away.
Checked my email to find that in there. How nice looking is that? Never mind that, not a collector thing above. :wink:
I’m really digging the Civivi Dogma!
Can anyone recommend some large Chinese budget fixed knives for me?
Something like the Harnds HK5006 (Desert Fox) would be ideal but the only seller with stock since it’s been discontinued wants too much for them.
The Brother F001 looks interesting but I’d prefer something larger.
Thanks for any help.
How about Morakniv knives? They are reputable with a pretty wide selection of prices, I own two and they seem to fit my large hands quite well.
I have one and it’s a lot smaller than I’m looking for, I want something heavy duty and about 10”/25cm overall. The Mora (Bahco 2444) is about a inch and a half shorter has a delicate thin blade.
I have a Bahco 2449 wrecking knife and a Hultafords Heavy Duty GK knife which are both bigger and have thicker blades but I’m looking for something bigger than those as well.
That looks like a great alternative to the Prawn. The thinner 0.12" blade stock should be a much better fit for that blade length. The S35VN should be much better for EDC.
I haven't tried any of the premium Bestechs but my experience with their budget knives has been fantastic. Fit, finish, and action are all excellent and have actually improved since the Pebble was released. If you end up getting one of these, please share your experiences with it here.
The Desert Fox is currently $60 on Amazon. What was the going price when it was in production?
I ask because if you love the knife and you love the sheath, that might not be terrible. It looks expensive compared to fixed blades in 9Cr18Mov from Schrade, CRKT, etc. but those are junk. My experience with Harnds has been okay. Compare it to decent fixed blades in 9Cr18Mov from Real Steel or Steel Will: https://www.bladehq.com/cat--Fixed-Blade-Knives--179#/filter:price:40:90/filter:blade_material:9Cr18MoV
Beyond that, do you have any preferences regarding steel, sheath type, etc.? For another $10, you could get a Ruike Jager. The Jager is a very nice fixed blade. It's a little more compact but still a good size. I prefer that kind of sheath for regular carry. It's also 14C28N. Its particular balance of toughness, edge retention, and corrosion resistance makes 14C28N a great choice for fixed blades.
I recently purchased this J. E. Made Nessmuk. I don’t know anything about the manufacturer but I believe they are a Chinese company. This is a superb knife.
The LW Boa II is an excellent knife for the money
Got this qsp penguin in green micarta with D2 blade. Very nice knife for the money.
I have it in blue. They’re definitely worthy of the praise they get.
I have the same green QSP Penguin. Got it from Drop. But mine has a very weak detent and the blade easily falls open, so I’ve never carried it. Don’t want to reach into my pocket and get surprised by a sharp blade.
Something is wrong with yours then. The detent is very decent on mine.
To bad it is a great knife.
I have this knife, too, and it has a very nice detent. If you have a torx set, see if the pivot screw is loose, it might just need to be tightened.
I also have this knife and mine is decent. Like some other people here, I got it on Drop when the price was irresistible.
Remember that things can go wrong in production. Every once in a while, a lemon can squeak its way through Quality Control. That seems more common in this tier of budget knives. Besides trying lots of different budget knives for myself, they tend to be my default gift for others (in addition to flashlights). I inspect, clean, and lube every single one of them including disassembly whenever possible. I've seen issues with QSP, Ganzo, CJRB, Tangram, and even Kizer's Vanguard line. If it's something I can fix myself, I do. Otherwise, I contact the company. Most of the time, they want to make it right. So if adjusting the pivot tension doesn't work, contact QSP.
my penguin detent is also good
I think the Civivi Ortis is a great budget option at $40, I got the black blade with OD handle.
That sucks to hear. As Swabs suggested, Hopefully it is an easy fix.
I’ve been thinking about getting one. Every Civivi I’ve bought has been flawless.
