From 10.1 to 10.8, we are on holiday so we cannot send the packages during this time.We said we will increase the price of RD6018 to 73.5USD from October, so here is the plan, 10.1-10.8 we set the price same as RD6012 as a compensation, after 10.8. RD6018 73.5USD/RD6018W 77.5USD
Super fast delivery. Reliable beautiful packaging. The quality of the power supply is excellent. All parameters are correct. Responsive, sociable. I recommend.
excellent power supply. used with huawei r4830n, set the voltage to 58 volts, the output is stable 54 volts 18 amperes. at the back I additionally made 2 connectors for voltage from a 58 Volt 28 Ampere power source. I recommend.
hello, the 11-11 shopping promotion is coming, you can wait a few days, from 2020.11.11-2020.11.12 aliexpress will offer coupons, usually aliexpress will give $6 coupon for every $65 order, for single RD6018, you can get 6 USD off, and for whole complete set, you can get 12 USD off at least
RD6018-W is shipped to the apartment(Ukraine) in 20 days from Hong Kong via Germany in excellent packaging. Done excellent. Responsible seller - I recommend!
the 11-11 promotion is coming, from 11-11 to 11-12(PT), you can enjoy bigger discount, and there are extra $65-$6 coupon, so it is a good time to order the RD series power supplies
please do not set 0A when you want to get output and the output terminal, if you set 0A, no matter how you adjust the output voltage, the actual output voltage is always 0
