It isn't important, that you have an Exduct account with your BLF username - you can have every username you want. Some of us, use their BLF usernames, others not.
Then use the BLFcode "BLFgiveaway" (without ""). If we have bought enough (and the forum get the 5x $20 coupons) Vectrex open a new thread (he did it in the past and maybe in the future, too) like this one:
You have to write in the thread raffle thread, which order number is yours and maybe you will win one of the $20 coupons.
I will open the 3rd raffle thread as soon as we are at $100 commission in the pot again. We are currently at $41.48. You can see the winners of the second raffle here. It is only important to use the coupon "BLFgiveaway" (case sensitive) during check out on your order to participate on the 3rd raffle which will be held later.
You still can.... just buy another knife or some accessories.... and from my side it's absolutely OK, if you participate in raffles... just make sure it's only 1 entry and it's all good.
Only a little... please hold yours eyes open for the upcoming 3rd participation thread... I will open it as soon as we reach the $100 commission mark (now at $44)... I assume It will take a few weeks till we have filled up the pot completely.
No problem, thanks for doing this and organizing! Congrats to the previous winners. Summer is slow, lots of people are away so it will probably take a bit longer.
Good idea, please auto enter me. I think I will miss the third entry thread. Usually I just check the posts on the front page, so any thread hard to find I wont be able to find it/forget.
I will try to remember you... but it is best to look for the thread yourself...with organizing such things chances are high that some details will be overlooked. The reason I don't open the thread now, is that on the 1st raffle some people misunderstood the rules and entered anyways.... on the 2nd raffle were I posted the specific order number range that didn't happen... so it's a little easier for me... I hope everybody understands that I want to minimize the work involved. And yes I will announce everything here in this thread... same procedure as every year,James... I mean Kreisler.;-)
Earlier this week I received two knives that I ordered after winning in last raffle. I chose one srm 962 (got the last one), and also one Enlan EL-01BA, black half serrated blade. Well what can I say. I like the looks of both of them. The 962 with smooth scales is a bit more pocket friendly, and it opens smoothly. However I unfortunately got some blade play mostly horizontal. I now have around 10 knives from China and all previous have less blade play. Anyways, I still like it. It looks robust and well made otherwise.
The Enlan on the other side is a gem with no play at all. It opened a bit less smoothly, but a drop of oil fixed that. Beautiful quality on that one. However, I wonder how long the black anodization will last if heavily used. Feels like the stainless steel version might be better for edc. Thanks again for this raffle.
Too bad the 962 isn't perfect, have you tried to tighten the pivot screw a little? That might help with the blade play... horizontal is easier to fix than vertical. I believe Enlan uses titanium nitride coating on their blades... so they should hold up better than most anodizations that we see on budget lights. Look at this thread for details.
Thanks Vectrex for the info about the titanium nitrate coating. Seems to be quite tough stuff. I also wonder how the serrated part of the blade manage edc usage. I have an srm T01 half serrated knife that I used the serrated part yesterday to cut off a thin plastic strap, and the edges after that wasnt straight anymore. Not that bad, but anyways… It was just plastic I cut. Regarding the pivot screw on the 962 I havent tried tighten it yet. I have to find some suitable tool for that first.
I assume your 962 has the 5 point pivot screws? Maybe this thread helps. The serrations are next to impossible to resharpen for me, so I only order plain edges. Even the sharpest knives will get dull at some point.
