Cyclone C88 with 6xAA -finished!
Jamio, JohnnyMac, Gary, dthrckt, et.al - I like the idea of carrying an extra battery holder and/or trying to mod a couple for efficiency. Can you guys tell from the eBay photos which would be the better one?
They look the same to me except for color. Both have similar construction with contact points and mods needed. Order one of each.
I think likewise, they are the same just different color and the whites are a bit cheaper. I already ordered two whites, when they arrive I'll post if they are different from the one shipped with cyclone.
Well, technically you are right about this when considering lower currents e.g. med 0.8amp. Because eneloops have very good discharging curve the difference between using one+one spare 3AA pack or one 3s2p will be very little in this case.
But we are all interested in high outputs and long runtimes, aren't we? (now with AAs)
Why wouldn't the OP be correct? It is very simple, once again example for full current 2.8A:
one AA battery pack = 2.8amps load per pack (and each battery in pack)
two parallel AA packs = 2.8a / 2 = 1.4amps load per pack (and each battery in both packs)
Then just compare on discharge graph (datasheets for eneloops are here) and look how much mAh it will give till voltage drops below LED Vin (+voltage drop on driver) at given current. Generally, the lower current draw from battery the better for battery, advantage of lower current draw with two parallel packs will be even more significant with lower quality AA, alkalines or in cold weather, when runnig the light on high with single pack wouldn't be possible, or very short only.
mio
Hello all, I had not much time last few days to write but was still working on this project to move it forward. I see there are few of us interested in this idea yet and I feel the problem is that I have no real data about runtimes and performance, nothing to show that it really works as expected. Now good new is that I've finally found a supplier who is willing to make a first prototype of the extension tube with a reasonable costs!
I estimate it will be done next week, and I'm still waiting for my two AA carriers. (I ordered almost month ago) So as soon I'll have all together and build, I'll run the runtimes tests with light output, temperature.. everyone interested hold on for a while!
I would also like to try and mod the default pill, it works good, but I'm curious if it could be better :)
So for now with a lot of not confirmed, let's wait till next week and then will see if this mod is actually worth it.
Yes, jayrob’s mod is nice, but of course it could be done for less than $50 for the whole thing, minus 3 or 4 AA batteries. Depends on who and how.
I wish you luck with it and I look forward to seeing what you have come up with. Modding is the essence of invention (I think), so good for you, for trying it out!
Yes the price is much better if you can save costs of international shipping for mag and all the parts needed. Also if you can do the parts for yourself.. Anyway, after cyclone will be finished, mag is very close to be another flashlight to mod, guess everyone here owns at least one
Things have moved forward today and finally the ordered battery holders arrived! What is even better - the extension tube was finished meanwhile also and fits the Cyclone very well, have a look at pictures!
About the new battery holders quality - they are the same as the one shipped with Cyclone, as expected, I'm really curious how they will perform in parallel. The extension tube is not anodized yet and I will only paint it black, for testing will be good as it is. Now as soon as I build the batt.holder will do the tests and post the results!
Nice jamio, looking forward to how this ends up.
I would probably leave the tube silver myself, black paint will probably look bad close up
When do you plan to modify the battery holders?
Will build the holder tomorrow and test in the evening, that is the plan.
The battery holder is finished! I didn't want to rush things and rather let the glue dry during the weekend. Here are pictures of how I made it, maybe it'll be usefull for some of you
1 - cut these metal sheets as marked (be sure to cut the right ones, one on (+) and one on (-) side, as the arrows pointing)
2 - remove the metal sheets on the other sides
- now I soldered to each one little brass pill for better contact, but this is optional
- prepare two about 12cm long wires and solder blue to (-) and red to (+) sheet. The blue is soldered on top side (as seen better on next picture) and the red is soldered on the inside - it is better for (+) protection against accidental short circuit with flashlight tube or driver
3 - drill hole in the plastic wide enough for the (+) cable, put the cable through and glue both sheets back to plastic holder
- here is detail of how the blue cable is soldered, unfortunatelly I forgot to take image for the red cable, it is soldered from bottom of the sheet
Now on the sides that will be glued together:
4 - cut small groove for blue cable, ideally with A shape so the cable 'click' in - this will help later at gluing
5 - bend the cables as on picture, cut for proper lenth and solder them to parts cutted in first step
6 - clean both plastic surfaces (I used alcohol),
- apply enough glue in the middle of both plastic parts, also coat cables with a little glue
(the glue layer will be about 3mm thick when both parts are glued - the cables are glued in between and their thickness make those 3mm, so the best is apply enough glue in the middle and when both parts are pressed together, glue will fill the space)
7 - carefully put the metal sheets on place, each on opposite holder, (easy because cables are long enough) align cables and press both parts together
- fill the glue where its still missing and remove excess glue
Freshly glued, I used white Mamut glue from Den Braven, holds like crazy and the work is very good with it
While the glue was drying, I also soldered the springs to the contacts
And, final 3s2p holder - just added red/blue insulating tape to the ends to avoid accidental wrong inserting
All parts are the original used in holders, there were only little brass pills added on each end and springs were soldered. I'm very curious how many amps will this modified holder be able to provide. I didn't test it yet but will do it very soon... Now the next I want to do is direct-solder led to custom copper heatsink similar to Match's latest test. If all will go well the heatsink will be made this week!
So this is it for now, will post any update I'll have
Gotta give you props, you are making it happen!
Nice neat job you did, I bet it works great. Thanks for posting the tutorial.
Nice mod, good work
Thank you guys, I tried to make it good as possible and went out pretty well, still it could be better
I did a quick test of the holder - driver, led and holder were only wired together (without soldering) on the table as flashlight is still disasembled while I'm waiting for the heatsink. So from 3AA I measured 2.45amps, from 6AA it was full 2.8amps. I don't like that it gives only 2.45amps with 3AA, have to work something out.
Hello, I have another update on this project and I really thought this time it will be completed &with all the tests. But sometimes things go different than one want :~ …and now it just needs more time. Okay now what was done successfully:
Made a custom copper heatsink - it is much more massive than the default one, the heat transfer contact with the body tube is 3 times more than before (I slightly increased the total height and also removed some anodizing inside the tube, for better heat transfer)
I really wanted the led to be directly bonded to copper heatsink but didn’t wanted to solder cables to those tiny pads on top of led base, so I did it similar way how lambda is mounting the leds to heatsinks, thanks for inspiration! :slight_smile: (or I think I saw it there)
Soldering the led was very easy as both parts fit very well, first presoldering the middle part with tiny layer and then add the led and cables:
…and after all this was finished, I was not carefull and scratched the emitter badly :cry: It still works but it really needs to be replaced. I changed my default t6-3c led for u2-1c and unfortunatelly had only 1, so now it has to wait till I get the new one. I should be more carefull until finish, I know……
I know how you feel about damaging the emitter. I managed to just touch one with the soldering iron leaving a small black spot on it. luckily it scraped of and seems to be ok. Looking forward to the completion of this.
I have read about some guys here that had success with polishing out scratches in the dome of an XM-L with a q-tip and plastic polish. May be worth a try.
Well done, can’t wait to see the end result!
I would certainly give it a try but I’m not sure how to do it properly, do you have a link?
