That shopper :steve: doesnt need the prize badly hehe..
You still can.... just buy another knife or some accessories.... and from my side it's absolutely OK, if you participate in raffles... just make sure it's only 1 entry and it's all good.
I bought a Bee knife with the BLF code...Confirmed Order 8099
I hope you dont have to jump through hoops to enter like in all the other contests here, LOL.
Only a little... please hold yours eyes open for the upcoming 3rd participation thread... I will open it as soon as we reach the $100 commission mark (now at $44)... I assume It will take a few weeks till we have filled up the pot completely.
No problem, thanks for doing this and organizing! Congrats to the previous winners. Summer is slow, lots of people are away so it will probably take a bit longer.
Vextrex please post here the news (3rd raffle) too so that subscribers to this thread are automatically alerted ;)
thanks you
Good idea, please auto enter me. I think I will miss the third entry thread. Usually I just check the posts on the front page, so any thread hard to find I wont be able to find it/forget.
I will try to remember you... but it is best to look for the thread yourself...with organizing such things chances are high that some details will be overlooked. The reason I don't open the thread now, is that on the 1st raffle some people misunderstood the rules and entered anyways.... on the 2nd raffle were I posted the specific order number range that didn't happen... so it's a little easier for me... I hope everybody understands that I want to minimize the work involved. And yes I will announce everything here in this thread... same procedure as every year,James... I mean Kreisler.;-)
No problem I understand that its difficult enough to track and organize, let alone entering people when its not even started yet.
I can find the thread again, will it be under the Deal Alerts section?
Take care.
That's good to know - I had no idea where to look either.
It's easiest just to subscribe to this thread here.
Earlier this week I received two knives that I ordered after winning in last raffle. I chose one srm 962 (got the last one), and also one Enlan EL-01BA, black half serrated blade. Well what can I say. I like the looks of both of them. The 962 with smooth scales is a bit more pocket friendly, and it opens smoothly. However I unfortunately got some blade play mostly horizontal. I now have around 10 knives from China and all previous have less blade play. Anyways, I still like it. It looks robust and well made otherwise.
The Enlan on the other side is a gem with no play at all. It opened a bit less smoothly, but a drop of oil fixed that. Beautiful quality on that one. However, I wonder how long the black anodization will last if heavily used. Feels like the stainless steel version might be better for edc. Thanks again for this raffle.
Too bad the 962 isn't perfect, have you tried to tighten the pivot screw a little? That might help with the blade play... horizontal is easier to fix than vertical. I believe Enlan uses titanium nitride coating on their blades... so they should hold up better than most anodizations that we see on budget lights. Look at this thread for details.
Thanks Vectrex for the info about the titanium nitrate coating. Seems to be quite tough stuff. I also wonder how the serrated part of the blade manage edc usage. I have an srm T01 half serrated knife that I used the serrated part yesterday to cut off a thin plastic strap, and the edges after that wasnt straight anymore. Not that bad, but anyways… It was just plastic I cut. Regarding the pivot screw on the 962 I havent tried tighten it yet. I have to find some suitable tool for that first.
I assume your 962 has the 5 point pivot screws? Maybe this thread helps. The serrations are next to impossible to resharpen for me, so I only order plain edges. Even the sharpest knives will get dull at some point.
Yes it has the 5 point pivot screw. Thanks again for the link. Might try with some needle nose pliers, or with your trick with a fork security bit. Are those readily available at hardware stores?
And regarding serrated edges, I agree, but I just had to have that enlan with it for the looks
At least in Germany they are available in bigger hardware stores... if you take your knife with you, you might be able to test what works best. It's a pity that the knife manufacturers couldn't agree on one standard screw for the bigger knives. 3-point, 5-point and now the new triangular screw... I don't see myself spending $15 on a tool for a $10 knife. 8CR13MoV is the steel used on most of the blades from ED and I noticed that it is more brittle than ... let's say 420 steel... probably due to its higher hardness. So they don't take abusive tasks too well.... but they are very affective slicers.
Because SRM discontinue for these models: 905,962,910 etc,So we have no plan to produce 5 pivot screw tool,
So you now just use a plier instead.BTW,when you try to loose the screw,pls make it hot first,because there is put some glue,you'd better to melt it,then would be easier to loose the screw.
Abt 3-point screw tool,i still waiting for production.i will use it match work with Enlan knives.
Hi! Is there any way to find out how close we are to the next raffle. I'm having trouble deciding what to order and would like to estimate how much time I have to decide (before the next raffle).
