Review: Cyclone C88 from Int'l Outdoor Store
_the_, is the lux output during runtime ceiling bounce value?
Yes. But measured by my meter in my room etc. => not comparable to any other readings. Kind of arbitrary unit..
Thanks Foy for the runtime data! So the 2500mAh Eneloops don't offer much more runtime at all compared to the 2000mAh's? Seems a little odd to me. Why is this? Why spend so much on the 2500mAh's then?
Also, Foy, is your King Kong INR Raised-top or flat top? I'd like to know if the raised top INR will fit? Here's my measurement on my raised-top INR (minus 0.50 for the plastic disk = 68.05mm).
EDIT: They don't fit according to rikr! See here. Dang!
Thanks!
-Garry
My INR is a flat top . . . the paper is the back page of my Tenergy charger booklet so, about the thickness of two sheets of paper?
@_the_
My Eneloops are 1900 mAh.
Foy
Hi guys
Does anyone have any ideas about how to mod this light so protected 18650's will fit? I recently purchased a couple of protected Panasonic NCR18650A cells as pictured here: http://www.ebay.com.au/itm/280769021348?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
They are good for 5A sustained even with the protection circuity, so they are otherwise very suitable and I'd love to be able to use them. The ones I have are exactly 68.8mm long.
Also, since 18650's are thin, how does one adapt them for use in this light? (I'm interested in this even if there's no way to mod the light to make protected 18650's fit, since I also have some unprotected cells as well).
Hi cainn24,
I was planning on using these adapters to get the 18650s to fit (together with the o-rings that come with the light for 26650s):
http://www.intl-outdoor.com/18650-to-26650-battery-converter-case-sleeve-p-235.html
I would waste more than $1.88 in time trying to make my own. Of course I have to wait weeks to get one from China.
As for the length of unprotected 18650s, I'm hoping - since I also prefer the protected cells) that adding an o-ring to the body of the flashlight body will suffice. Seems like I recall seeing a post about someone doing that.
Aloha and welcome to BLF cainn24!
@blinded
Thanks for the reply, and the information. I'll definitely remember to add one of those 18650 to 26650 adaptors to my cart if I decide to go ahead with a C88 purchase. The problem is that I really want to phase out my unprotected lithium battery use, rather than add a device to the mix that needs them. It's not so much about the (albeit minor) safety concerns as it is about the convenience of not having to micromanage charge and discharge scenarios (being able to lend my flashlights out, at full performance, without worrying so much, is one such scenario). It's one of the reasons I spent $15.00 per cell on the best protected 18650's I could find.
@fishinfool
Thanks for the welcome! I've been lurking around here for a couple of weeks and learning a lot about flashlights in the process. This forum is a great resource with some great people it seems :)
Welcome aboard, cainn24!
Just got my light but forgot to order the 18650 to 26650 adaptor at the same time. Bummer!
Just use a couple of o-rings . . . . that's all I use, works perfect.
Foy
Cool. Thanks!
Ummmm I seem to be missing something here. The gap between the 18650 and the casing is much bigger than the width of the o-rings. Clearly I’m missing the obvious but any chance of a photo showing how you do it?
There are also larger O-rings than those for flashlights, from plumbing for example.. some plastic pipe or even wood would also work. Or a cardboard roll from toilet paper. Or... there are a lot of possibilites. :)
I found 3/4” electrical conduit works well generally. I don’t have the Cyclone C88 though. Standard 3/4” water line PVC will work, but I found the electrical conduit to be slightly wider so it gives less wobble in the flashlight body.
I thought the 18650 to 26650 adaptor came with the light? Edit - I see they don’t and they aren’t even listed as an “add-on”.
-Garry
It came with mine….
Thanks for the help guys!
That’s what I thought but it actually only comes with spare o-rings and lanyard.
Sorry rufus, I should have been more specific. The o-rings need to be a little bit bigger.
Foy
I went to a meeting of UK torch [flashlight] chaps last weekend. During the evening one of the guys set up his IS in the pub and we tested many lights. One of them was this light. Measured 694 ANSI Lumens on a 26650.
Hi Foy, I’ve not yet converted myself to the 26650, and was looking with curiosity at the JM-07. Now this “special” version C88. Would you please be so kind to elaborate more on the differences between the two? Any beam comparison possible?
Thanks :slight_smile:
