tdoom15
(tdoom15)
1
I might be able to pick up a dereelight c2h body with a dereelight javelin head...now all I need is a p60 drop in to go with it.
I was told both the 1 and 5 mode xml from KD would work? will it with a standard 3v cr123, not 16340.
If not, I take it an xpg r5 would be the next suggestion for max output?
I'd like to spend less than $20 on the drop in if possible, so any suggestions would be great as I'm pretty new to drop ins etc..
Budgeteer
(Budgeteer)
2
Perhaps this one:
- Battery configuration :
18650 3.7v x 1pc
CR123A 3.0v or 3.7v x 1pc
- Runtime : 18650 3.7v – 3.5 hours CR123A 3.0v or 3.7v x 1 – 1.5 hours
old4570
(old4570)
3
Make sure you go 0.8v to 4.2v Low voltage drop in if you plan on running primaries ...
The normal 3v to 4.2v drop in will not run on primaries , nor will the 3 - 8.4v one .
