Test / Review: PALight BR18650 3000mAh (Yellow)
14 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 21 min ago
DSC_0546
Official specifications:
  • Operating voltage: 3.70
  • Capacity: 3000mAh
  • Ultra-high capacity and premium built quality
  • Protected to avoid over-charged or over-discharged
PALight%20BR18650%203000mAh%20(Yellow)-info
This battery only has about 66% of rated capacity and cannot deliver high current.
DSC_0537 DSC_0540
DSC_0544 DSC_0545
DSC_0541
DSC_0542
DSC_0543
PALight%20BR18650%203000mAh%20(Yellow)-Capacity
The two batteries has slightly different capacity and can only sustain a 3A load for some time.
PALight%20BR18650%203000mAh%20(Yellow)-CapacityTimeHours
PALight%20BR18650%203000mAh%20(Yellow)-Energy
PALight%20BR18650%203000mAh%20(Yellow)-PowerLoadTime
The battery can only sustain a 10 watt load for a short time, then the over current protection trips.
PALight%20BR18650%203000mAh%20(Yellow)-TripCurrent
The over current protection trips at a very low value.
PALight%20BR18650%203000mAh%20(Yellow)-Charge
Conclusion
The battery has much less capacity than stated on the cell and can only be used with light loads.
The batteries can barely rate as acceptable for a cheap battery.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
scaru
scaru's picture
Last seen: 3 years 10 months ago
Thanks for the review HKJ.
HKJ
HKJ's picture
As I have written before, I plan on adding a few of the cheaper brands to the test. It will just be a very limited sample of the cheap batteries, even if I wanted, I do not believe that I could keep up with the new discount brands introduced.
BetweenRides
BetweenRides's picture
Last seen: 2 years 2 months ago
Thanks, HKJ: telling it like it is!
fishinfool
fishinfool's picture
Thanks again HKJ!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
BanglaBob
Last seen: 1 year 4 months ago
ALTP batteries (avoid.like.the.plague)
Many thanks HKJ
Lights out! That's when things get interesting...
Shaquille
Shaquille's picture
Last seen: 2 years 3 months ago
another one of ultrafires brc 3000 s relative  Tongue Out
sb56637
sb56637's picture
Last seen: 8 hours 17 min ago
Thanks a lot for another detailed review! Frontpage’d and Sticky’d.
ri chevy
Last seen: 1 year 1 week ago
Thank you. You have a high degree of integrity HKJ. Smile
Ecig
Last seen: 7 years 10 months ago
I received uprotected Palight, 3000mAh, with some good Palight flashlight (C9 gray with R5) from Dinodirect
Batteries were junk, they had several hunderds mAg capacity, felt very very light in hand.
zeremefico
zeremefico's picture
Last seen: 3 hours 44 min ago
More cheap batteries test please!!! Big Smile
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Sardion Master
Sardion Master's picture
Last seen: 8 years 1 month ago
HKJ : Thank You for another money saving review.
Men occasionally stumble over the truth, but most of them pick themselves up and hurry off as if nothing had happened.
HKJ
HKJ's picture
zeremefico wrote:
More cheap batteries test please!!! :D
Please supply some links to batteries/shops, that you want tested, then I will consider it. Remember that it takes between 1 and 2 months from I order a battery, until it is tested (Time might be longer, if my pile of batteries grows again).
zeremefico
This cell looks interesting: http://www.manafont.com/product_info.php/samsung-icr-18650-2800mah-recha...
Your work is highly appreciated!
edit: Alsothis http://www.manafont.com/product_info.php/sanyo-unprotected-18650-flat-co... from the same supplier.
My YouTube channel
K40M F16
