Noob here, hello all. I’ve read all I can read in the last 10 days or so and it seems like an endless tunnel. I need some guidance to see if I’m on the right trail.
I want to use torch lights to put on my bicycle handle bar to ride city light and non lit bicycle trails. I am new to bicycling and not having any lights, I have not ridden at night. My travel time is usually below 1 hour. I’m narrowed my selection to Solarforce L2 for front lights, I will get just one unit. For my use, is it ok to just use the regular L2? I’m confused about the drop ins. Solarforce sells a XML- 3-8.4v 5 mode light. I am unsure if I need 5 mode (mainly for the strobe function) but thought to get one just in case. I have read about recommendations to get the drop ins from Outdoor store, they also have a XML T6 5 mode. Both selling at about the same price, I don’t understand what the differences are and which to prefer.
For the rear lights, I was wondering why no one is using a torch as a rear light? I would prefer strobe rear, I found this item, Ultrafire WF-501B Philips Luxeon K2 Red LED Flashlight , reading the reviews, people are saying it’s only about a 40 lumen torch. The item is cheap, about $10, it is only one mode:
I found Solarforce also sells red LED 5 mode. Solarforce Red 225Lms P4 Cree Led Bulb 4.2-8.4v.
If the production of glare is a problem for people behind the red LED lights, I was thinking of putting some kind of filter to soften the light (like bubble wrap). I have also found red colored cones and red filters, so I should be able to use these instead of a red LED drop in ( they are pricy at $10 each):
Would the above work? I would like recommendations on 18650 batteries and chargers please (I have not gotten to reading about battery/charger since I’m stuck with the above). I think my needs are pretty modest, I am looking for a simple system. Thanks for letting me pick your brains and for your assistance.
Welcome to BLF exe! Stick around and enjoy it! There are lots of threads on cycling lights, batteries, and chargers around here. (You’ve probably done your share of searching.)
Sorry I don’t have enough time to respond in detail, but that Int-Outdoor C8 module won’t fit a “P60” style host (like the L2/L2P’s you linked). If you’re sticking to P60 format you need a P60 drop in like this one at Int-Outdoor (expensive). A lot of people like the Ultrafire 3 mode from Manafont, but it’s only Hi-Med-Low (no strobe or SOS). Manafont has a 5 mode version but I’ve never heard any review on it.
The P60 format doesn’t handle heat well, but you will be ok on a bike while moving. You might consider moving up to the C8 format which will handle heat better. Consider one of the nicest C8 lights raved about here - the XinTD C8 which is available with various modes and a cool white or neutral white tint.
Batteries? Probably needs to be based on your budget and runtime requirements. Lots of people like the Xtar 18700’s. but they don’t fit all lights. Trustfire Flame 2400mAh’s (from a reputable dealer like Manafont) have been good budget batteries. The 3000mAh version of those batteries have tested at about the same capacity and therefore not really worth getting. Xtar chargers like the WP2 II have been well liked (early models had issues which seem to be resolved now).
Other’s can chime in on more batteries or chargers. I’m no expert, just chiming in with my 2 cents.
I’m actually leaving this Sunday on a +/- 300 mile cycling/camping trip and plan to use my fake L2 with the Ultrafire 3-mode drop-in for my main light (although I don’t plan on riding in the dark - I’m gonna test it though like a good flashaholic would!)
Where are you based? I ask because I bought my front and back light set up from a scotish based seller on eBay (i’m in England) I got a specific front and rear light, the front is high medium low strobe with an English legal (three flash/second I think) stove and an ultra high output rear light, this is cool with a continuous high output led and strobe at the same time, again the strobe is English legal frequency.
The front light is what turned me onto modern high output LEDs, its driven off 4 x 18650’s mounted in a small pack that can be fastened to a mountain bike bar mount, I add a cable tie to the included loops to secure the pack, I’m unsure of the battery configuration, could be 2s2p, the light head is about the diameter of a 50 pence piece and the rear on off switch glows different colours to indicate charge level (blue full, green 70,orange 40,red less than 15% I think)
It’s dropped about £20 since I bought it and is a fluxient light, not much info available but it is awesome, both in run time and illumination, I won’t use it on high on the road, it forces cars to pull over 8) offroad the combination off throw and spill from the Xm-l is hard to beat from a single source, many people go for a bar mount for flood and a lid mounted thrower to follow their eye line.
gord1001, I’m in Victoria Canada. I’d like to stick to self contained flashlights, it’s more convenient to take one item off and on instead of multiple straps. I’ll consider the helmet mount at a later time.
Garrybunk, what is the difference between the C8 you linked and a L2 with the XML U2 drop? (ok I guess it’s a format difference, I assume C8 is bigger).
Fair comment, shipping to Canada would be ridiculous to be fair.
The c8 is a similar size tube with a larger head than the l2 say 42mm reflector compared to 26ish mm I think, the xintd c8 xm-l gets a very favourable review both in reliability and construction, it would be a good choice.
Who you need to comment on this is “between rides” maybe worth a pm to nudge him into commenting, I don’t know what he currently runs, but it maybe a 26650 c8 size light to give extra run time along with flood/throw, I think you want a good combination of both on a bar mount, with this size a keygos m10 is a consideration, it seems to review favourably, is available on eBay generally with two cells and a charger for not much cash and can have the driver replaced fairly cheaply if you get the bug and want more output :bigsmile:
Welcome exe, great bunch of flashlight people around here , a great bunch…
On the bicycle lights, I am a cheap skate, and I follow the code of BLF, that is, getting budget lights. For my bikes, I run PAIRS up front, one on the helmet, and was running a small torch in the rear, but still working on that…
My favorite, is the Keygos M10…Goes for $21.39 shipped on Ebay. The other one is the Keygos Ke-5, going for roughly the same price on Ebay. The M10 is a 26650 light, and the Ke-5 is an 18650 light. Right out the box, these lights are ready to burn a hole in the darkness.
The lights you have listed in your links are good too. But, that red torch is not a blinky. It is almost universal to run a blinky in the rear…
Yes, the C8 is a larger headed light with better heatsinking and will generally give more “throw” (but not narrow beamed throw).
I’d be tempted to tell you to look at the Cylcone C88 at Intl-Outdoor due to it’s battery versatility running on either a 26650, an 18650, or 3AA NiMh’s. Would be tougher to mount though and a bit pricey.
Hi, Exe, welcome to BLF. You have a good start in your OP. I’d follow Garry’s advice on the 3 mode P60 drop-in from Manafont. Most cyclists don’t use and don’t like Strobe or SOS modes. I actually detest them. All they do is annoy people in front of you. Unless you are fixed on having them, avoid is my recommendation. Some commuters will disagree with me on that… I also like the idea of having two lights on the bars, one with Smooth reflector for throw, the other with Orange Peel reflector for flood The L2 or L2P are great lights and will give decent throw. A C8 style will be just a bit better.
I think you can do better on mounts, but the one you chose will work ok. I think you should buy several each of different types of mounts and use the one that works best for you. They are cheap enough to experiment a little (I have about 15 mounts, use 2 types regularly). For quick removeability and all around versatility, try this one: Loading... This is like the one you linked to, but a little better quality plastic and it swivels: Loading... This is a very solid mount, but takes a bit to remove: Loading...
For rear blinkies, I don’t know anyone using a torch. Blinkies are cheap and easy to mount - they are made for this application. I generally run 2, one up high just below the seat bag, the other down low on the left seat stay. I prefer blinking mode - it’s annoying but attention getting, which is what you want. SuperFlash style work really well, as do the Blackburn Flea LEDs. They are bright! - visible from 1-2 miles away. cehoward turned us all on to an ebay seller a while back that had SuperFlash clones for about 1/5 the price you will pay for the original. Great spend - perhaps he can post the link later or I’ll come back with it after a little searching.
Anyway, good luck and remember to experiment until you find what works best for you. If you are anything like the other knuckleheads around here, you will end up buying a buttload of flashlights while you search for the perfect cycling light.
OK, so to narrow down what you all wrote.
Front lights: *either XinTD C8 or Keygos M10. Both can take 18650, the M10 can also do 26650. Any additional pointers as to which is better?
I don’t think I will take the Cylcone C88, I don’t want to have mounting problems.
Rear lights:* cehowardGS, what rear torch have you used? What do you think about the 5 mode Solarforce Cree red LED that I linked in my OP paired with a L2? Or using a regular white LED and pairing it up with the two items I linked to difffuse, a red cone or red filter.
BetweenRides, I wanted to use rear torch instead of the blinkies because the torch cost just as much ($20) but I will have simplified the battery using 18650, and will probably have much better run times between charge. Thanks for the mount links, I think your look better.
Both have less flood and more throw than my old lights. Of the two the XindTD has a tighter hot spot (larger smooth reflector), so if you want a bike light with a floody beam pattern for your handlebars this may not be the best choice.
I’m not sure which other XML based lights offer more flood?
Paired with Trustfire protected 26650. Any recommendation for chargers. I have narrowed down to Trustfire TR005 or TR006. They differ in the charge rate, 1.5a vs 1a.
I will get the first two out of the 3 mounts recommended by ‘betweenrides’.
Now since most items will come from Manafont, I was wondering do they list the entire value of the items? In Canada I can import tax free $20 worth of stuff. So I can do multiple orders if I have to.
I’m loving my Cyclone C88 (discovered through this forum) and am looking for a solid bike mount for a Trek Navigator 2.0 handlebar.
My main requirements (besides fit for the 38mm body) are that it does not move up/down over somewhat rough terrain (swappable rubber liners of varying thickness would be great) and that that the light is secured, not just dropped into a rubber “U” grip.
