I took the wrapper off one of the batteries:
Theres print on battery:
HFR NI-MH 120417
I have no idea, googling brings up only Alibaba brandless battery results, it doesnt find anything with 120417 tho, only with HFR NI-MH.
Alibaba links say Place of Origin: Guangdong China (Mainland) Brand Name: HFR
Perhaps this is the manufacturer:
http://www.haopengbattery.com/en/introduce010.html
Anyone know anything about these Sanyo Harmolattice
All I know is they are LSD, 2500mAh and 500 cycles (same as XX eneloop)
Well, $15 is really good price for re-branded & pretty XX’es!
Really shame that it’s only seller & he doesn’t ships internationally, I’d so take a 4-pack of these.
+1 on that, 15$ for XX Eneloops is a bargain, but shipping would probably kill the deal for us because we can get them for ~21$ locally.
Little update regarding my fake DinoDirect Enepoops - their capacity range from 1800mAh to 2400mAh, I will test 4 of them for their LSD properties tomorrow, 2 days after I charged them, next 4 I will test in a week, if its going to be worth it, it depends how good data will turn to be after 2 days of self discharge.
If its promising, then 1 month test is due.
Have you contacted DinoDirect about the issue?
(I still haven´t received mine)
I have, its been 5 days and NO reply from them, I opened up a case in resolutions center, left a message today there to see whether anyone will reply or not.
I bought these for my brother through his account, looks like Im keeping them and resolving this case as well
these are the Eneloop XX in a different wrapper.
I think we talked about them earlier in this thread.
The numbers are not really good, most likely fakes. 2400 is way too high, and 1800 is not so good either
Same specs as the XX/Pro, just a different packaging? There are posts on the internet about these going back to January 2011. They seem to have been marketed in Malaysia and the Philippines based on the posts I’ve seen.
Oh no, you guys actually have ordered Eneloops from DD. Hope you get your money back!!
I would not done it for any price, knowing what they send at random as TF Flames etc.
I just got a mail back from Sanyo.
Dear xxxxx,
FYI the only different between double x and Harmolattice is double x come with pre charge technology but Harmolattice is not.
Thanks and Regards
EDDY CHOOI
SANYO Energy(s) Corp., Pte. Ltd.
Consumer Products
Regional Sales Executive
Tel: +65 6 6730 8192
Fax: +65 6396 0881
HP: +65 9152 5275
Email: eddy.chooi@sg.panasonic.com
Website: http://www.eneloop.com.sg
Harmolattice is advertised coming pre-charged.
I found this on the other forum:
XX is for the European market and there is an equivalent Harmolattice 2500mAh (with the Eneloop technology) for the Asian market. Unlike the XX, Harmolattice are not pre-charged.
Here are my numbers after charge-discharge cycle of my fake Eneloop’s from DinoDirect:
1-1823mAh
2-2183mAh
3-2313mAh
4-2015mAh
5-2409mAh
6-2278mAh
7-1966mAh
8-2109mAh
9-2530mAh
10-2420mAh
11-2468mAh
12-2370mAh
Initial discharge tests of 4 batteries after 2 days:
1-1895mAh(1823mAh charge capacity tested)
6-2331mAh(2278mAh charge capacity tested)
9-2416mAh(2530mAh charge capacity tested)
11-2388mAh(2468mAh charge capacity tested)
Not all that bad really. But no way those are Eneloops.
i posted a freshly taken picture of the 7th cell of the Eneloop Glitter 8-pack. it's the 3rd cell from the left. as you can see, it is numbered (bears "#7").
These kind of products make me feel good. joy-bringers!!
Just was looking through this thread and noticed the background on the above picture. More evidence. :P
Thanks for the results, vëer.
No need to say any comment about those fakeloops.
Meanwhile…. I imagine that they still haven´t answered you about the received fakeloops….
Let´s see what they tell you. If they tell you something.
I am guessing that they will offer a 3$ giftcard per each pack you bought………
PS: I think that those batts are not LSD. I will do a 6months LSD test from mine
Definitely not real eneloops but should be good for use around the house. You can use and abuse them and not feel bad about it.
Yes, you can abuse them……. unless they start a fire
hmmmm… I will try to do a discharge test at 1 or 2 amps to see if they can do well under high loads…………
