The numbers are not really good, most likely fakes. 2400 is way too high, and 1800 is not so good either
Anyone know anything about these Sanyo Harmolattice
Same specs as the XX/Pro, just a different packaging? There are posts on the internet about these going back to January 2011. They seem to have been marketed in Malaysia and the Philippines based on the posts I’ve seen.
Oh no, you guys actually have ordered Eneloops from DD. Hope you get your money back!!
I would not done it for any price, knowing what they send at random as TF Flames etc.
I just got a mail back from Sanyo.
Dear xxxxx,
FYI the only different between double x and Harmolattice is double x come with pre charge technology but Harmolattice is not.
Thanks and Regards
EDDY CHOOI
SANYO Energy(s) Corp., Pte. Ltd.
Consumer Products
Regional Sales Executive
Tel: +65 6 6730 8192
Fax: +65 6396 0881
HP: +65 9152 5275
Email: eddy.chooi@sg.panasonic.com
Website: http://www.eneloop.com.sg
Harmolattice is advertised coming pre-charged.
I found this on the other forum:
XX is for the European market and there is an equivalent Harmolattice 2500mAh (with the Eneloop technology) for the Asian market. Unlike the XX, Harmolattice are not pre-charged.
Here are my numbers after charge-discharge cycle of my fake Eneloop’s from DinoDirect:
1-1823mAh
2-2183mAh
3-2313mAh
4-2015mAh
5-2409mAh
6-2278mAh
7-1966mAh
8-2109mAh
9-2530mAh
10-2420mAh
11-2468mAh
12-2370mAh
Initial discharge tests of 4 batteries after 2 days:
1-1895mAh(1823mAh charge capacity tested)
6-2331mAh(2278mAh charge capacity tested)
9-2416mAh(2530mAh charge capacity tested)
11-2388mAh(2468mAh charge capacity tested)
Not all that bad really. But no way those are Eneloops.
i posted a freshly taken picture of the 7th cell of the Eneloop Glitter 8-pack. it's the 3rd cell from the left. as you can see, it is numbered (bears "#7").
These kind of products make me feel good. joy-bringers!!
Just was looking through this thread and noticed the background on the above picture. More evidence. :P
Thanks for the results, vëer.
No need to say any comment about those fakeloops.
Meanwhile…. I imagine that they still haven´t answered you about the received fakeloops….
Let´s see what they tell you. If they tell you something.
I am guessing that they will offer a 3$ giftcard per each pack you bought………
PS: I think that those batts are not LSD. I will do a 6months LSD test from mine
Definitely not real eneloops but should be good for use around the house. You can use and abuse them and not feel bad about it.
Yes, you can abuse them……. unless they start a fire
hmmmm… I will try to do a discharge test at 1 or 2 amps to see if they can do well under high loads…………
When I discharged them at 1A they became rather warm, when I charged them at 2A they became really HOT to the touch, so I wouldnt say these are going to be reliable batteries
I wont trust them and wont charge higher than @1A charge rate.
muahaha
At least they can be discharged at 1Amp, because the PISEN AA LSD 2000mAh I have, when you try to discharge at more than 500mA…………. they simply…………. die
PS: what charger/discharger are you using vëer?
MAHA C9000, best purchase related to batteries/flashlights so far
Got it from German Ebay for excellent price for European buyers, bare charger and set with bag and car adapter, battery box available:
Mine came in perfect box, even tho seller advertises that some of boxes might have slight damages.
BTW, got reply from DinoScam.com - they say that they checked and that those batteries are not fake, LOL!
F*K DinoDirect, F*K them hard!
TX, too expensive for me… I can´t afford it. I will continue using my Imax
BTW, got reply from DinoScam.com - they say that they checked and that those batteries are not fake, LOL! FK DinoDirect, FK them hard!
veer, DD is *just a big* etailer and they are no specialists re the stuff they sell. i am sure that none of them has technical knowledge re flashlights, and for example ever disassembled a switch!! neither will they know how to discern fake cells from original cells. even *we* have a hard time telling, dont we? so here are general suggestions re buying from DD:
1) solve your case in repeated chat sessions with changing ottas. dont use their email system or other delayed communication form.
2) avoid buying batteries from them. even DX gets to sell batches of fake TF's. the only reason for me to buy batteries from them is if i have run out of ideas what to buy from them with my tens of 2$ or 3$ giftcards.
I guess I will have to open PP dispute and then start to bomard them with chat requests. Still its their responsibility what they are selling, not buyers.
first chat bombarding. if no results, then open PP dispute. after that continue bombarding with chat requests. since you’re online now, do it now. their chat is (again) 24/7!!
Doesnt look like they are 24/7…
Picked these up from the post office yesterday.
Edit: Added some info at the beginning of this thread about the Sanyo Harmolattice.
@vëer and others:
I have started to test my FAKELoops from dino
These batts ARE NOT LSD. And no need to do a 6 months LSD test. Why?
I compared how much the voltage drops after charging…. I mean, I measured how much voltage drops on a LSD battery and on a non-LSD battery.
I have found that:
LSD battery: after charging, the voltage remains above 1.4volt even after several days
NON-LSD battery: after charging, the voltage drops from 1.4volt to 1.37 in less than 1 hour.
For me, no need to waste time and money doing a 6 months LSD test.
