Trustfire S-A6
Reviewer's Overall Rating: ★★★★
Summary:
Battery: | AAA / 10440 |
Switch: | Twisty |
Modes: | 5 |
LED Type: | Cree XP-E Q4 |
Lens: | Feels like glass |
Tailstands: | No |
Price Payed: | $17.10 |
Date Ordered: | 23rd December 2010 Arrived 22nd January 2011 |
Pros:
- Stainless steel
- Bright for an AAA light
- Very solid body
- Good beam quality, typical of XP-E
- Works with protected 10440s which are too long for many AAA lights
- Twisty switch so basically nothing to go wrong.
- Will accomodate most AAA/10440 cells, certainly all the ones I threw at it.
Cons:
- Quite expensive - for a budget light.
- Engraving on the back
- Didn't work on arrival
- Mode changes quite tricky
- Body too long for AAA NiMH - need to use magnets as spacers
- Stainless steel so gets hot on high with a 10440
- The neck chain gets in the way of operating the switch. When doing mode changes for the beamshots it got painful.
- Enough threading for it to be a battery crusher - a modicum of care needed here.
Features / Value: ★★★★
Arrived in the typical Trustfire box. As boxes go, it's not bad though the styling could be more subdued by my preference. Note it says 500m range. That will be right! The same way that I can spit 500m.
I wonder what "Circuit Controlling" is?
The box is filled with closed-cell foam which is quite dense and gives good protection to the light in transit. It does add 50 grammes to the shipping weight (The light weighs 83.4g with a protected 10440) but I reckon it gives better protection on three sides than bubble wrap and reckon the box is a worthwhile addition. Others may disagree. Certainly it didn't stop my one from arriving in less than working condition.
It did work, briefly, then stopped working. After a moan to DX - still waiting for a response, I decided to take it apart as what did I have to lose?
It comes with some rather odd engraving on the back. It might be possible to grind this out, but I went for a less effortful solution. The finish is a sort of slightly dulled mirror polish which shows every finger mark.
Design / Build Quality: ★★★
The innards. Essentially it is a lump of stainless steel with a reflector and lens in one end and a plug switch at the other.
With a protected 10440 in it. Note the dog hairs. My assistant is terribly generous with her hair - you open a can of beans and there's a dog hair floating on top of it. :(
The switch/tailcap. It appears to be quite well made, if not very well finished on the back end. There are what appear to be file marks on it. If I could be bothered, I'd polish them out with a Dremel. It isn't noticeable to my ageing eyes without magnification.
The light emitting end.
Reflector and light emitting end innards. The black thing is to stop the back of the reflector from shorting out the contacts on top of the LED. The reflector is metal. DX says the glass is coated. If it is, some Chinese factory has invented invisible coating. and ineffective coating...
Looking down on the pill. That's a lot of thermal goop. A lot more than is necessary or desirable. It may be thermal epoxy rather than silicone heatsink goop, I forgot to check.
The pill. The thread only engages at the bottom - you don't have to unscrew it for an hour to wind it out, you just need a few turns then can push it out with a pen or the like. But it took the hour of trying before I discovered that.
The source of the problems was the good old perennial of the pill's being loose. No problems since I tightened it down hard. But it is losing a couple of stars for that. It has a lot of similarities with the Trustfire XP-E F23 - the output is almost the same. Whether it is worth the extra $4 depends on whether you like the styling or not. I do like it apart from the taped over engraving on the back. It is less than a fifth of the price of the similarly styled (AA battery) Xeno Cube which I consider to be an incredibly desirable (But very non-budget) light.
Battery Life: ★★★★
Giving it four stars forwhat it is - this is reasonable by the standards of silly output AAA lights. It isn't something to buy for a whole night's illumination unless you own a lot more 10440s than I do.
Runtimes and current draw to be done. I'd not expect much over 12 minutes on high with a 10440. This is typical of the breed. I'd be very surprised if the runtime graphs turn out significantly different from the Trustfire F23's.
Current draw:
High: 1050mA That is pretty fierce for a 10440!
Medium: 450mA
Low: 100mA
Here are the F23 charts till I generate S-A6 ones.
Light Output: ★★★★★
Light | Battery |
Trustfire S-A6 High | 10440 |
Trustfire S-A6 Medium | 10440 |
Trustfire S-A6 Low | 10440 |
Trustfire S-A6 High | AAA NiMH |
Trustfire S-A6 Medium | AAA NiMH |
Trustfire S-A6 Low | AAA NiMH |
Trustfire S-A6 High | AAA |
Trustfire S-A6 Medium | AAA |
Trustfire S-A6 Low | AAA |
It isn't as bright on a 10440 as the ITP A3 EOS Upgrade but you are specifically warned not to use that light for more than a few seconds on high with a 10440. Output is at the same level as the Trustfire XP-E F23. This probably represents the maximum practical output from a 10440 sized light with current LEDs and drivers.
All beamshots done with a Trustfire protected 10440.
Ceiling. As ever, the bluish patch is the camera's sensor, not the light. The beam colour apart from the blue bit is what I'm seeing with my eyes.
Outdoors
Control
Low
Medium
High
Comparisons
ITP A3 EOS Upgrade with 10440 Low
A3 Medium
A3 High
Akoray K-103/10440
Trustfire F23 Low/10440
Trustfire F23 High/10440
Ultrafire UF-H3D lowest/18650. This is not intended for distance use - it is primarily a headlamp.
Ultrafire UF-H3D Highest/18650
Summary: ★★★★
It is quite big for an AAA light, but not the biggest. Top to bottom, the enormous Mr.Lite J4 (With the switch from the BLF variant) it is the only AA light here, the rest are AAA. Aurora SH0031, Trustfire S-A6, Trustfire F23, Akoray K103, Tank007 TK-703, Mr.Lite KC-05
Upright
I like it, but it is a flawed light. Nothing is glued so it's easy enough to fix. But they shouldn't ship them with loose pills. That and the engraving I could live without. I don't think i could have justified more than four stars for this light. I do like it, it has been my constant companion since it arrived as it is a rather good bright searching under the desk light. The chain is just long enough for it to sit in a shirt pocket - but i am below average height and the chain would definitely be too short for people much taller than I am. So I'm giving it four stars overall and I'd probably do the same even if there had been no fault with the pill.
