Test / Review: Intl-outdoor UR14500P 840mAh (Black)
  • Sanyo UR14500P Protected Battery
  • Protected against Overdischarge, Overcharge and Short-circuit
  • Capacity: 840mAh
  • Recommended Max Discharge: 1.68A (2C)
  • Max discharge: 3A
  • Full charge: 4.2V
  • Nominal voltage: 3.7V
  • Model: Sanyo UR14500P
There is a very good match between the two tested batteries.
The protection trips at about 3A, this is a good value for this cell.
Conclusion
There is not much to say about this battery, with a Sanyo cell inside, I will call it a very good battery.
Notes and links
The batteries was supplied by intl-outdoor for review.
Thx HKJ, good to see more choices for sizes other than 18650.
EDIT: will you be adding these to your 18650 comparator?
No, I hope to make a small battery comparator with 16340, 14500 and likes, but it will probably be more than a month before I have time for that (I need to do a couple of other reviews first).
The usual great review HKJ - thanks. I missed these on Intl-Outdoor’s site (which I look at almost daily :slight_smile: ). Obviously new, and good choice - I;ve bought Trustfire flames on recommendations here.
So these are best protected 14500’s out there, at the moment?
I cannot answer that, they are only the 3. 14500 I test and their performance looks extremely close to the Keeppower ones.
But keeppower ones aren’t available for purchase anywhere :frowning: Only decent ones available for purchase are AW’s and Eagletac’s, which both seem inferior to this one.
Thanks again HKJ!
Thanks as always for the great review! Frontpage’d and Sticky’d.
