Forgot to add about battery options. The most economical solution is using a rechargable 18650 Li-ion. It will also give you longer runtime.
The drop in bulb you listed says it has five modes, my flash light currently has one mode and I bought it for that reason. If I buy that drop in red bulb would it the be a 5 mode? And thank you for the welcome, although being a Favre fan you are probably nice to everyone seeing as how you probably have no friends. LOL
P.S.
I shoot as far as I can identify the target! Daylight 300+ yards is acceptable. At night maybe 200 max.
Not quite the same, but way cheaper:
http://www.manafont.com/product_info.php/pressure-switch-for-ultrafire-501b-flashlight-55cm-p-4991
[quote=petefixer]
P.S.
[/quote]
…Now that’s a mean thing to say … I love it…match has friends … He’s not the only one who rides in that short bus…:~
###I would NEVER suggest anyone buy a 501B...i think it's so cheesy (no pun intended ).. just can't say enough bad things about that host .. spend 6 more bucks and get the solarforce ..Trash never starts to smell any better ..bad stuff..save yourself the pain of it.don't buy it .
first off, what rifle are you mounting on?
if your mounting on an AR with a rail system, that makes mounting ALOT easier
second, do you want to keep the flashlight you already have?
heres a few options
1) what i would do
http://budgetlightforum.cz.cc/node/1150
^thats an all out option, you will need a different driver
2) just replace the LED with this (keep the current flashlight)
with the same driver, if you only draw .7 amps from the tailcap (easy test with a multimeter) if not change the driver too.
this option will run as little as $6 up to $15 at WORST. you take the pill out, unsolder the LED, (at this point if driver replace, unsolder that) and reverse with new led and/or driver
502B does have mounting and wire options. and i like it ALOT for a flashlight (well i have a 502D, but its basically the same, just twice as long)
I would also buy some 18650s and a charger. well worth the run time upgrade. ill be getting some tenergy 18650s soon
I think is it possible to modify this light to be red and still as bright, but the detail I also don't know, use a red filtered lens maybe the fastest way to solve your problem.
I can tell there is alot of options out there for this light, I guess what I am looking for is a red light atleast as bright as this one in red. I am going to be mounting it to the scope on top of my Tikka t3 .22-250 I have a Nikon Prostaff scope, which has a 1 inch tube. The links Tas62 gave me say the accessories are for a 501B is that going to work on my 502B? I have also seen on another sight somewhere there is a led that I can drop in it that is a 1 mode and produces 900 lumns of light, it is not red but maybe I want one of those too, ant truth to these? I dont remember where I saw it though. This stuff all seems so cool, I really gotta start learning how all this stuff works.
Hi, I'm also a noob when it comes to flashlights (we call them torches :) ), but i'm pretty well versed in physics. When dealing with different colours (colors ;) ) percieved brightness changes. For example a green light will appear a lot brighter than a red light at the same lumen output. Human eyes just happen to be more sensitive to lower wavelenghts. Also our eyes detect smaller differences in contrast with green light. Remember "green screen" computer monitors ? They were green for a reason, easier on the eye. Now I don't know about coyotes, but dogs see in black and white with some sensitivity into the red wavelengths. They probably don't see red as a "colour" but they can certainly detect it. This is just a wild guess but coyotes may be less sensitive to green light than red. Worth exploring the possibility at any rate, that is if green leds are available with the required power output.
Good hunting (although personally I'd prefer it if you let them be, I also aknowledge that farmers need to be able to grow food, such is the dichotomy of human existence).
Red colored lens might be really the quickest solution along with:
http://www.manafont.com/product_info.php/ultrafire-pressure-switch-tail-part-replacement-55cm-p-4999 <- easy to swap if you have pointy tweezers.
The 501B host isn't that bad if youre not a flashlaholic. But beware, there are several versions around i have one that lens replacement is very annyoing.
I would go this way tho:
TOTO88 | Bocoran Slot Gacor Hari Ini Might be nice and easy to mount and dismount.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 <- or something like it Might be a cree P4 rated max 700mA… But should be ok at 750
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 but only 1 needed might be needed to kill one amc to get 750mA
Not very cheap but not costly either for a great potential.
The red cree led myight stink because of the lovely description on KD.
Nice rifle/scope setup. To answer your question, the accessories from the 501B should work just fine for your 502B.
As far as the drop ins you come across, take the lumens rating with a grain of salt. Most aren't driven to the full potential and won't put out anywhere near what they're marketed as. ( The p7 is notoriously overrated at 900lm). Another thing to keep in mind is that what you're really after is throw - i.e. you want to illuminate those furry little buggers in excess of 200yds. That quality is more a function of reflector type than than sheer lumen output. Case in point:
My rifle light of choice is a Tiablo A9 with an ashperic lens. At most it's putting out just over 200lm, but can light up a varmint at over 300yds. Compare that to my new XM-L based solarforce that's pushing out over 600lm, but is only really good for half that range (and very floody). To give more of a visual, here's the Tiablo as compared to my solarforce:
I don't have any beam shots handy, but might be able to scare some up later. As stated already, there are a ton of options. If this is to be a dedicated rifle light, I may suggest getting a dedicated thrower and just using your current 502B as a general use light. There are quite a few good thrower options that are pretty inexpensive.
*Offtopic: What part of Wisconsin? I grew up just north of the Twin Cities, but Gramps had a cabin over in Luck, WI... Spent a lot of time over there and around River Falls. I've been down in S.C. for just over six years, but really miss that area (not to mention the size of the deer back home...the average SC deer is equivalent to a standard yellow lab).
"There are quite a few good thrower options that are pretty inexpensive. " Any of them in red?
I live in the very northeast corner of the state 10 minutes from the U.P. border. The deer are big here but there is not many around anymore. I am not against buying a different light at all, but what should a guy buy? Idealy I would like a light that will throw 10 miles on a single AA for about 300 hours on high, and of course be red. I just cant believe there isnt one out there. All kidding aside, I want the most powerful longest range light there is in red. However as always I want it cheap. Can I get anymore difficult? Anything as bright as mine or brighter in red would be excellent. Anymore suggestions?
Yes, still standing at my version but involves some DIY because of the RED requirement.
Pressure switch - http://www.manafont.com/product_info.php/ultrafire-pressure-switch-tail-...
weapon mount - http://www.manafont.com/product_info.php/y0004-flashlight-and-laser-univ...
FlashyLightey - http://www.priceangels.com/SKYRAY_1JC8_Cree_Q5-WC_230-Lumen_LED_Flashlig... Might be nice and easy to mount and dismount.
RED thing - http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 <- or something like it Might be a cree P4 rated max 700mA... But should be ok at 750
Decent driver - http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 but only 1 needed might be needed to kill one amc to get 750mA, Might as well get it elsewhere
Well under 40usd... and a bit of soldering to get exatly what you want but you perhaps don't know it yet. :P
For your needs i would go the DIY route. If you were my neighbor i would gladly make one for you if you provide the pieces. Time needed (without soldering iron heat up) 15min at most... and that with lubing and cleaning included.
Perhaps you can find some1 around who can make it if oyu don't want to go the DIY route.
I completely agree with what you say however, I have no idea what all this means exactly. "but only 1 needed might be needed to kill one amc to get 750mA, Might as well get it elsewhere" what are you talking about? Seriously talk to me like a child.......whats an amc or what is it that I need to kill? Is this the part that needs soldering? I can solder, I am a master diesel mechanic and can navigate though truck electrical systems with no problem, however this stuff kills me. Is there a flashlights for dummies video somewhere? I wanna build what you are saying but dont know how to begin even.
Naah it is me that needs to be more reasonable and stop assuming all understand those flashaholic terms. :)
You got almost all right.
Let me redo the list in english or close to it:
Pressure switch - http://www.manafont.com/product_info.php/ultrafire-pressure-switch-tail-... Nothing to say here
weapon mount - http://www.manafont.com/product_info.php/y0004-flashlight-and-laser-univ... Pretty self explanatory bu you might need another one and already know which one you need so here you're on your own
RED thing - http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 <- or any other cree P4 whose are rated max 700mA... Those can be bought at other retailers too also on ebay if you like.
Decent driver - http://www.kaidomain.com/ProductDetails.aspx?ProductId=1708 <- this one sells 5pcs a pack. You need only one. If you get a cree emitter p4 red rated at 700mA you may unsolder one of the 4 AMC chips to drop the current to 700mA or get this instead: http://kaidomain.com/ProductDetails.aspx?ProductId=9608 but i would advise to not since it is hard to ever use that many boards rated at 700mA...
As for "you might get those elsewhere" it does just mean you might get lucky at other retailers selling single drivers. I always buy in bulk those... :/
My english is what it is. Since i speak a handfull of languages i tend to mixup a bit. Also suffering from slight dyslexia by trying to type fast.
Yaaawn... i hope it sounds decent this time. :)
Now if you feel comfortable with a soldering iron in hand you can do it just easily. We will help you step by step if needed. :)
You may also need this:
thermal glue of some sort - http://www.dealextreme.com/p/fujik-silicone-thermal-glue-50ml-grease-like-4579
Oh the other hand you might need just this:
And cut some red cellophane like: http://www.enasco.com/product/9700879%28A%29
And try if the red is good enough since it would be hard to get sutable red lenses of that diamter.
Pretty cheesy way to do it but it may work. I suspect the cellophane will kill a fair amount of lumens too espacially if you need more layers. Might be tricky to do it as best a s possible. Perhaps painting it might do the trick.
I know astronomers use red lights to light up star maps or what ever they need to see as for reasons I can't quite remember red doesn't effect your night vision.
How well do red replacement lenses work? As that might work as an alternative to a red LED which would then give you a lot more choices, like a XM-L dropin from Manafont.
http://www.solarforce-sales.com/product_detail.php?t=FA&s=27&id=143
I've no idea about gun stuff but it looks like Solarforce do suitable mounts and switches to go with their bodies.
XML drop in would give me about how amny more lumens than i currently have? This drop in is exactly what is says? Just drop it in place of the old one right? No mods needed? I am figuring this drop in and a red lense might work? And I wouldnt have to even know how to solder then right?
Oh and can I get it in a single mode?
It may well be that an XM-L dropin with a red filter will give you more light than a red LED. My brightest one measures at a peak 850 lumens. Swapping a dropin is a matter of unscrewing the head, taking out the dropin and putting a new one in. It is a good idea to wrap high-output ones in heavy aluminium foil until they are a tight fit in the throat of the light to allow for better heat transmission to the light body. It's no harder than changing a battery. You may want to take a spare battery though - at full output you are only going to get around 40 minutes till the battery needs charging.
