Review: DQG III AAA Ti NW (pre-production version)
18 posts / 0 new
_the_
_the_'s picture
Last seen: 3 days 9 hours ago
DQG III AAA Ti NW (pre-production version!)
Reviewer's Overall Rating: ★★★
Summary:
Battery: 1 x AAA
Switch: Twisty
Modes: 2 (Low, High - No memory)
LED Type: Cree XP-G R4
Lens: TIR, plastic
Tailstands: Yes, perfectly!
Price Payed: $57
Date Ordered: May 2012
Pros:
  • Very small, perfect for key chain
  • Very lightweight, only 9g!! (19g with battery and claw!)
  • Titanium, light and durable material for key chain use
  • Good grip, knurling is even more aggressive than in SS version
  • Tailstands, perfectly
  • Good beam pattern
  • No PWM
  • Constant brightness
  • Long (enough) runtime
  • Well spaced modes
  • Good UI (mode order, no memory)
  • Magnet in tail
  • No battery rattle
  • Doesn't eat O-rings
  • Threads were perfect (no free play at all)
  • Very nice small claw + 2 extra O-rings included
  • (Final version comes in a nice tin box, without company name, suitable for gifting!)
Cons:
  • A bit pricey (but I paid the difference with joy - this thing is so good!)
  • Threads were dry (but very smooth, a small amount of silicone grease helps to make it perfect)
(bolded items are enhancements in the Ti and/or III-versions)
NOTE: This is a pre-production version. Design of the tail has changed in the final version!
Features / Value: ★★★★
As a pre-production version, this light came without any box. The final production version will come in a tin box similar to the earlier one, but without the CNQG text => perfect for gifting! Here you can see the earlier box for reference:
The box contains the light itself, two extra O-rings, split ring, and claw. Also this photo is from earlier version, thus showing also the larger claw.
Features are quite simple: Main "feature" is that the light is so small that you can hook it to your key ring and forget it - until you need light. The light has two well spaced modes, about 3 lumens and 60 lumens.
UI is very good, or actually the best for this kind of light: Tighten head to turn on (= low). Loosen to turn off. Turn off and on again for High. No memory means no unpleasant surprises and makes sure you won't lose your night vision by accident!
Ric promised to include the smaller claw for anyone pre-ordering this light. I got it also and I have to say that I like it a lot! The original BOYOU claw was good, but the new one is significantly smaller & lighter and suits this light very well. See the difference in the following photo. DQG III SS with original claw above, Ti with new claw below:
Value for money: Good! Even though the light is a bit pricey, the small size, lower weight and good features are worth the price difference.
Design / Build Quality: ★★★
Design is just prefect. The size is great for key chain use, and so is the material. Titanium can take even more abuse than stainless steel, which is needed when the light repeatedly hits your keys during the next few years. Titanium version is also very lightweight - even if I never had problems with the weight of SS version I think that the titanium version is more balanced in my key chain.
Knurling is very nice, a bit more aggressive than in the SS version. Not too aggressive though => very suitable for a key chain light. If I had to choose which knurling is better, I would choose this one.
Here's a comparison to DQG III SS (Ti left, SS right). Please note how the knurling design is changed again a bit. This together with the more aggressive knurling seems to work well, as the light is very pleasant to operate, also with one hand.
Let's take a closer look to the knurling. Head:
..and the knurling of the body. Machined very well, I must say!
A look to inside. Nothing there, not even a tail spring.
The threads were very smooth, but dry. The first thing I did was applying some silicone grease and I was happy with the threads thereafter.
The slot for O-ring is clearly separated from the threads also in the titanium version, helping to keep the O-ring in place and prevent damage. A small, but very important detail!
Some people complained about the head slop in the SS version (I didn't have that problem in any of my three III's), so I did double check the threads and free play of this light, but I didn't find anything to complain. See the photo below for the tolerance between head and body:
Another important feature can be found on top of the driver board: A foam insert, which eliminates the battery rattle, also when turned off! Note also the machining quality: Very clean!
The TIR lens is flawless and emitter perfectly centered.
Some measurements:
Length: 57.2mm
Head diameter: 12.9mm (a bit more than SS because of the more aggressive knurling)
Body diameter: 11.9mm
Weight: About 19g with lithium primary cell, split ring & claw (= ready to use), 9g without. And about 16g if you don't use the claw. Unbelievably lightweight!!
..and same as photos:
The bottom line in the quality: Machining is near perfect, absolutely nothing to complain! And the included new, smaller claw is the best I have seen so far!
Battery Life: ★★★★
Good!
I measured the current draw to be about 450mA on high and 20mA on low -> theoretical runtime would be over 2.5h on high and up to 50h on low (with a good lithium AAA primary).
Current draw is significantly less than in my SS version and it seems to be also lower than the DQG II, which took about 540mA. Also the brightness on high is a bit lower than SS, but it's hard to notice unless you are using lux meter => maybe not full 60 lumens, but then again: Better battery life.
I also tested the runtime with Energizer Ultimate lithium AAA (initially at 1.80V -> 3h down to 0.3V when the light was barely on): 2h 33min to 50% brightness.
Runtime graph below:
As we can see, the light is well regulated and maintains good brightness for about 2h 30min on high.
Light Output: ★★★
Just what I want from a EDC pocket / key chain light! About 3 lumens on low -> enough for small tasks and doesn't ruin your night vision. On high the promised 60 lumens seems to be a quite accurate figure and is certainly enough for walking on a small path or similar. The TIR lens provides a really nice beam pattern, which makes the beam look even brighter than 60 lumens!
The tint on the warm side of NW, but not too warm for my taste (note that I love neutral, but hate warm tints!). Hotspot is smooth and focused enough. This can be seen in the following white wall beamshots (WB: Daylight)
Low mode (Left III Ti R4/NW, right III SS R5/CW)
High mode with same exposure (Left III Ti R4/NW, right III SS R5/CW)
High mode, increased exposure to show the spill (Left III Ti R4/NW, right III SS R5/CW)
Beam angle (Left III Ti R4/NW, right III SS R5/CW)
 ..and then there is the GITD-feature. The head glows nicely after use:
Then some glamour shots:
Size comparison.
From left: DQG III Ti, DQG III SS, DQG II SS, 4sevens Preon P0, Klarus MiX6 & Thrunite Ti:
A family portrait.
From left: DQG III Ti NW (pre production tail!), DQG III SS NW w. magnet, DQG III SS NW w. glow dot, DQG III SS CW w. magnet & DQG II NW w.magnet
Summary: ★★★★
The DQG Tiny II and III have been my favorite key chain lights since the famous BLF group buy. The only things I ever complained about it were the battery rattle and the fact that it eats O-rings. So I had really high hopes for the new version and it lived up to expectations.
The stainless steel version was already very good, but if you want to have something even more durable and lightweight, the titanium is the way to go! I feel the price difference is not so bad, so I happily paid for the titanium and I'm very pleased with it. After all, this is my current EDC and thus the most used light.
Verdict: Highly Recommended!
The End (pun intended). Note that the tail design will be different in the final production version.
Thanks for reading & watching. Hope you enjoyed the review!
=the=
Edited by: sb56637 on 08/26/2014 - 17:12
kreisler
kreisler's picture
Last seen: 5 years 9 months ago
first to say thanks!!
good to see .. you're as passionate about the DQG Tiny specimen as i am about the Tank E09 evolution (colors, V1, V2, V3, ..). i hope that the lights never die on you -- financially, i cannot afford such expensive lights if they die on me. i do afford such-priced lights if it's a premium brand with 10yrs performance guarantee (4sevens, eagle tac): if their lights fail to flash during normal use which includes drops from normal use heights, e.g. 3 feet, warranty covers the defect and repair. fenix has some good service after the warranty period too.
may your specimen live long Smile
*FMI* i got 4 i/o sh
fishinfool
fishinfool's picture
Thanks for the review _the_!
Awesome pics too!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
SashiX
SashiX's picture
Last seen: 5 years 6 months ago
lol :bigsmile: couldn't agree more with you, kreis :bigsmile:
Very nice review, mate Smile I know it's TI, but... veeeery pricey anyway (for me). Great regulation, btw.
cd520
cd520's picture
Last seen: 6 years 3 weeks ago
Drool.............that is all.
Infinite
Infinite's picture
Thanks for review !
"Magnet in tail (or glow dot, the choice is yours!)"
Ric said the magnet is better on the new tail, so the new tail will come with a magnet. Is there still a choice ?
_the_
_the_'s picture
You are right. I stand corrected.
Ric really said at "the other place" that "As the magnet looks better on the new tail, DQG Ti will come with magnet."
And thanks for all the compliments! Creating these reviews takes much effort, so it feels good to hear that someone reads and even likes them. Smile
=the=
Misfire
Last seen: 2 years 1 month ago
Thanks for the review. Smile
Personally I feel like these lights are too much of a gamble given the (seemingly) lacking long-term support. If I'm gonna drop $50+ on a light then I want that 10 year warranty!
Getting back to the review, did you experience any galling of the threads when rotating the head?
_the_
_the_'s picture
Well. As I said, the threads were dry and I experienced some galling before applying the silicone grease, but after that the head rotates fairly smoothly.
There is still a bit more friction than in the SS version, but that's nothing I would be worried about.
About the price / warranty of budget lights: I have paid over $100 for lights that came without any warranty. That's always a risk when dealing with "budget" lights. But then again, similar light with warranty might cost $300-500, so I can get a spare one (or buy a new better model!) in case the old would break..
And paying $57 for a light that I use every day is not bad IMHO.
After all, I have to say that I have been very happy with the quality of DQGs. No other light of mine have survived so well from a ever day abuse in my key chain, occasional dropping to concrete floor etc. (One magnet popped out from my first DQG II, but I glued it back and it's good again.)
=the=
UPz
UPz's picture
Last seen: 1 week 3 days ago
Great review _the_ !!  Awesome pics!
I've just ordered one, with GITD and CW tint. I'll review it for the spanish community in my blog when arrives.
Thanks for sharing!
sb56637
sb56637's picture
Last seen: 11 hours 24 min ago
Thanks for another excellent review THE! Very well done. Frontpage’d and Sticky’d.
ri chevy
Last seen: 5 days 10 hours ago
Thank you for a great review.
UPz
UPz's picture
I received a notification last friday to pick up a parcel coming from SG post.
I really hope it’s the DQG Ti. Will tell you tomorrow Love
BetweenRides
BetweenRides's picture
Great review, thanks for posting.
Infinite
Infinite's picture
I received my Ti a few days ago. I’m very satisfied. The threads are better than expected. Even better than one of my SS Versions.
UPz
UPz's picture
Very very nice threads on mine too:
My review: http://reviewsdelinternas.blogspot.com.es/2012/07/dqg-iii-ti.html
scaru
scaru's picture
Last seen: 2 years 10 months ago
Thanks for another great Review UPz!
esrevenge
Last seen: 3 years 2 months ago
I just found this thread now, but thanks for the write-up, very nice pics and review.
