If it was up to me I would grind but I have no patience
Putting that kind of effort into such a sweet copper pill I would wait for the correct driver to arrive. Keep it all legit without a driver hack-job. Find something else to mill or mod this weekend, or just kick back, sip adult beverages, and relax for a change.
I have patience but not much of it as well. I procrastinate over spending 2 bob hence the question. Kids (young adults) cost more than I make.
This applies to so many situations - great advice! :bigsmile: :beer: :party:
You and I need to do this together one day.
I’d wait.
Grind, baby, grind.
Grind Hell, do it by hand with files. LOL
I could just give you a list of stuff you can do this week-end,
Stuff I need to be done on a lathe.
I suggest you wait and use a different/better driver. I’ve tried that one and discussed it here: Beast drivers @ Kaidomain ,
here: New XM-L driver on DX, anyone getting one? | Candle Power Flashlight Forum ,
and here: “http://www.candlepowerforums.com/vb/showthread.php?319237-Triple-MC-E-0D-Maglite-based-bike-light-MADE![](&p=3917275&viewfull=1#post3917275":http://www.candlepowerforums.com/vb/showthread.php?319237-Triple-MC-E-0D-Maglite-based-bike-light-MADE)&p=3917275&viewfull=1#post3917275
Bottom line, long story short, is that it throttles back from high way too early, even with potting for better thermal dissipation.
This applies to so many situations – great advice!
Thanks for the advice. Long story short (out comes the violin), early last year I had a prolapsed disc in my back. Off work for about 3 months on some rather strong pain killers. Being absolutely sick of being a pretty much disabled for an extended period of time I thought to myself to h_ll with it and took the super dooper mind expanding pills and proceded to work very proudly on my outside table that I have been building, no joke for 20 years. You could hear the screams 3 suburbs away. Bench saw, spinning blade and a thumb pointing backwards . Now your telling me I have to kick back and relax . The adult beverages happen anyway.
I would love to do stuff on the lathe for you but would that take away from the inspiration that you give us guys? We could not have that now could we.
I suggest you wait and use a different/better driver. I’ve tried that one and discussed it here: https://budgetlightforum.com/t/-/6905 ,
here: http://www.candlepowerforums.com/vb/showthread.php?312393-New-XM-L-drive… ,
and here: http://www.candlepowerforums.com/vb/showthread.php?319237-Triple-MC-E-0D-Maglite-based-bike-light-MADE!&p=3917275&viewfull=1#post3917275
Bugger. After reading for the last 2 hours all your links you have talked me into not using this driver unless someone can talk me into it. Ramps down from heat.
I'm almost to scared to ask if this one is any better,
This is the other one on order. Some of you may seen this already, this is what its going in.
https://budgetlightforum.com/t/-/9637
Thanks for giving me a relaxing, inebriated lay on the couch and catch up on recorded but not watched gp racing. Its 10 to 7 in the morning here. Is it to early to start?
If i may, i would like to quote one of the finest literary poets of our time
“If you don’t work you don’t eat, you don’t grind you don’t shine ” 281 330 8004
Here it is. The JM05 has a slightly bigger pill, edit, in diameter than the HD2010, so with a couple of measurements a bit of grinding, soldering and a few choice words this popped out of the shed at the end of the day.
Stock pill with 3 mode 2 .8 amp driver. New pill 5 amp driver. Stock pill with 3 mode 2 .8 amp driver. New pill 5 amp driver.
JM05 5 amp U2 1A
HD2010 2.8 amp U2 2S
It just goes to show what a big reflector like the HD2010 has does for throw. The JM05 has a far bigger hot spot that is not apparent in the photos. The 1A tint also looks washed out compared to the 2S tint. Both leds are XML U2.
I havent run the flashlight on high for very long as I'm not game. Maybe later when Ive had a couple more?
Thanks JohnnyMac for these words of wisdom, just kick back, sip adult beverages, and relax for a change and Techjunkie for your advice.
Very impressive what a beautiful piece of metal, great job.
I installed that driver in Kumabears 3 XML and I didn’t have a problem with it throttling back to soon. He posted in that thread about how pleased he was with it also.
I have just seen three new drivers at kaidomain, for leds in series at 3A each, for 5,7, and 9 leds, the one with 9 is rated at 100W... 5: http://kaidomain.com/product/details.S020167 7: http://kaidomain.com/product/details.S020166 9: http://kaidomain.com/product/details.S020165 Anyone has a compact host to do it? Haha.
Dude! Your machine work is outstanding! Lots and lots of respect! 8)
handsome piece of copper.
8)
Wow!! great work. Copper FTW!!!
YEP!
If i may, i would like to quote one of the finest literary poets our time
lol :money_mouth_face:
Thanks to you all for your words of inspiration.
E (and others). A couple of thoughts and questions. The soft thermal white blocks, where do they go and do they actually work. On the original driver swap I put it on the top driver board which slightly compressed it and is held that way with the bottom driver board soldered to the pill. On this one due to room constraints, I machined a step in the pill to just clear the windings to keep as much mass in the copper as possible, so could not put it there so I cut it into slices and wedged it between the driver boards. The driver also has a hum to it on the two lower current outputs. I know nothing about potting but would this silence it any. On reading there seems to be to different reasons for potting. One for electronic reliability against knocks etc and the other to get rid of heat. Does anyone know of any cheap homebrew recipes or can you use something like Araldite 2 part epoxy?
My soldering still needs a lot of practice as I thought that this pill being a lot thinner where I soldered the driver board to, that I would not have the problem I had last time in that the copper just wicks the heat straight out of the iron. Wrong. I cant believe how this material just sucks the life out of such a large soldering iron. The large iron below is the one I'm using for this use. It puts out enough heat that you could use it to brand a Mallee bull. I will have to use the oven next time when MRS dnf is not home.
Having slept on it I'm not happy with the night shots as I used different tint leds between the HD2010 and JM05 so today, all going well I will have XML U2 2S tints in them both to get a better idea of how they compare. Cheers.
