You don't get titanium for that price, and the only other, commonly used, thing that looks like titanium is anodized aluminum. If the threads are a lighter color than the body, then there is the answer to that. Haven't gotten mine yet, but stainless steel is supposed to not dissolve in a sodium hydroxide solution, right?
Sodium hydroxide won't do it much good - but won't eat it the way it will aluminium.
Always add sodium hydroxide to water - NEVER add water to the crystals - you will not enjoy the result if you do. Alkali burns are nastier in general than acid burns. And tend to scar worse - best to avoid the possibility.
It's far too hard to be any conventional anodised aluminium - because of the fine ribbing it makes a pretty decent file. It is of comparable hardness to type 3 hard anodising - I managed to mark a Fenix E01 with it though the Fenix also managed to mark the fine ribbing. I'm positive it is no aluminium alloy I've ever come across, but I'm no metallurgist.
It is very grippy without shredding clothing. I just wet and soaped one hand then held the light in it. I was going to break the lanyard before it came out of my hand. It was knurled then finely grooved - I've not seen one like this before but it seems to work well.
With the cell in it that I'd been using to play with it at every opportunity today (i.e., not fully charged) I got these numbers on high. 278 lumens at switch on, 261 at 30 seconds and 256 at two minutes. Throw was 7810 lux at 1 metre.
Unlike the Yezl from yesterday it only gets mildly warm - so is probably better designed internally for use with low thermal conductivity materials - the Aurora SH-032 is from the same school of thermal design.
The Yezl is a lot brighter. Like 50 lumens more at switch-on. Most I've seen from the Ultrafire is 1200mA on high. I'll try it with other cells and so on when I get around to a review. I really ought to add current draw to the spreadsheets.
Wouldn't the old fashion methode be good to analize the material? I mean, mesuring the mass of the body tube, by dunking it in a water container and then put in on a balance to get the exact weight.
That'd get me the density, but there are so many alloys out there I'd not be able to work out which one without chemical or spectroscopic testing. If there's any iron in it then it is an unusual looking stainless steel. It is just possible that the surface grooving that is causing the colour though it isn't that finely grooved.
I was thinking about mesuring its density before I made the caustic soda comment, but I first dismissed it as unfeasible. Thinking about it again, you actually only need to weigh and submerge the battery tube and not the sensitive head and clicky tail. Much better idea than using caustic chemicals! : )
One could also try testing its resistance at some flat part of its surface, aluminum oxide is a good insulator and should give an "OL" or similar read out while stainless steels should give a very low resistance reading.
My Yezl B6 and B2S Pulled the same kind of amps .On a 14500 that was run down to 3.71 volts on High it pulled 1.290A...med .950A low.160 A... god forbid if I charge that battery up to 4.20 but 3.7 volts is what the emitter wants anyway .
My guess is that density is a better bet. Al is a better conductor than Fe and it isn't that hard to penetrate a thin layer of anodising while trying to get a reliable contact. I'll need to go up into the loft and see if I have any measuring cylinders of appropriate size. Whatever the metal is, it has a very high magnetic permeability- which some steels do and many don't. What i mean by this is the NIB magnets I used to test were strongly attracted to the steel cased 18650 inside the light. This doesn't normally happen with Al lights though they tend to be thicker walled.
I certainly don't intend to strip out all the internals so only intend to measure the battery tube. Because of the fine grooving I'm going to have to boil it to shift any entrained air. A drop of two of a surfactant (AKA dish washing detergent) will also help here. But unless I can find a reasonably precise measuring cylinder with a large enough diameter (So the battery tube will fit in it) to measure the displaced water, there is no point in trying. Kitchen equipment will not be up to the job. Somewhere in the loft there is a 70 year old lab balance and weights for it - there may just be some volumetric equipment as well.
I'll take a look in the loft at the weekend unless anyone has access to non-destructive elemental analysis gear. I doubt anyone has such kit at home as it'd cost more than the house did.
It isn't really knurling - it is a fine grooving over all of it - even the knurled portions have the fine grooving on them. Here's an 80x magnification picture of a part of the head.
I assume that your car had a rather expensive repair bill. Sorry to hear about that!
After looking at the magnified pic that you took, I wonder if this was stamped or pressed in a mold from a metallic powder alloy and then kiln baked - as many parts in the automotive industry are these days.
