I don't own a P60, looking to get a Solarforce to remedy that.
$28 plus shipping usually $33 in the US and a little more outside.
I could order a normal L2 host and add this http://www.lighthound.com/Solar-Force-L2-Stainless-Bezel-Ring_p_3811.html
and this http://www.lighthound.com/Solar-Force-L2-Tailcap-with-Forward-Click-Switch-ver-L2-S11_p_3962.html to trick it out, right?
Yeah that’ll definitely work. You should be aware though that tall-crown strike bezels block OTF lumens on these lights. Its about a 10 Lumen reduction on an XRE module. It will be slightly more though for the large die, floody drop ins. The height of the bezel obstructs side-most emitted lumens, and creates a narrower field. It doesn’t affect the hot spot intensity though.
Ah, and flood is what I want. Would this slightly less crenelated bezel be better? http://www.lighthound.com/Solarforce-Stainless-Steel-Slight-Crenelated-Bezel-Ring-for-Solarforce-and-Lighthound-heads_p_3505.html
Could always get a smooth bezel otherwise http://www.lighthound.com/Solarforce-Stainless-Steel-Retaining-Ring-for-Solarforce-and-Lighthound-heads_p_2860.html
Solarforce L2P + E1320 P60 drop-in.
Get yourself Ace version :stuck_out_tongue:
Haha, EXACTLY what I was going to build by buying the parts, cheaper this way.
I dont like SS bezels.. but I only have one Solarforce, my blue L2P. And imo the L2P is really worth it.. the clicky just feels great.
Hmm I’m not sure about that mid-height bezel. I would imagine with a large die XML it would block a noticeable amount. I have never seen a deep bezel that didn’t obstruct at least a little.
My worst offender is the SF-M2, it blocks as much as 20 Lumens with the malkoff flood modules. Its not so much the lumen drop thats noticeable, its the narrower field of vision. An inch or two reduction here or there on a white wall isn’t really that noticeable until you get them out in the field then its like WOW… tunnel effect. So I use my lowest profile bezel with the Malkoff, so it still spills out to the far sides. The G2 and M2 are used with incan modules. The incan lamp filament is forward enough to help clear the deep bezel on these lights.
OOOOOhhh! Got this combo and love it. +1 here!!!
I personally have that strike bezel and this particular one DOES NOT obstruct the beam at all.
This is the one I have, and the next one I plan to get is the same thing in grey: http://www.solarforceflashlight-sales.com/product_detail.php?t=FB&s=7&id=418
I'm happy with the MF drop-in as it's very bright cool white and a good throw/flood combo, that and the reverse clicky are great for cycling. One of E's or the IO version will be my next drop-in. I love the 5 mode in the UF2100 that Erik built up.
i looked at a few SF links here and most of them weren't clear if the drop-in is included or not. if you already have a p60 pill and are still waiting for any host, here's one to keep you busy while you wait.
$4 for a complete xenon 501b. www.ebay.com/itm/261026706159. at time of this post he has 15 left. as fleabay deals go, this one will be gone in a blink. add a $5 xre p60 pill, and you have a $9 complete swappable backup for the solarforce. i don't know anything about this seller, just posting a good deal. :)
Listing already removed. Must have been a hot deal!
EDIT: Now back at $3.99!
http://www.customlites.com/P60-Nichia-NVSL219-4500k-92-CRI-P60-Nich-92cri.htm
Been thinking about getting this. Maybe something to look in to. IIRC, these are also current controlled.
For $29 complete, you might want to consider the Blaze at Shinigbeam
More than 10 available / 38 sold :expressionless: Check history (click on “38 sold”) and you will see that the first light was sold “May-31-12 20:35:51 PDT”.
As for SF - all links here are body/hosts only (without drop-ins).
EDIT: 40 bucks for Nichia drop-in? Those spring and pill must be made of gold :bigsmile:
I have some Nichia 219s, the same drivers and the same reflectors except mine are $30 shipped and you have more mode choices.
I have one in my beside light L2M with a 2 amp 5 mode 1 lumen low and a forward clicky for sneaking to the bathroom at night without waking up my girl. I have another in an AA host as my EDC have been testing for a while. It is really impressive how much more the colors show up with one of these, the only thing that comes close in color rendition is the 7B XMLs I have.
———————4B XPG—————————- 4C XPG —————————-Nichia 219
And ordered.
Yeeeaaahhh :stuck_out_tongue: Tell us what you think (once received, of course :bigsmile: )
