I’m not familar with the XP-G 2. How is it different than the XP-G?
Generally speaking the XR-E is the smallest and has the greatest surface brightness which equates to throw.
Most aspherics from places like DX only tell you the diameter so you buy something that will fit your host or if you have a bench grinder (for instance) you can get something close and make it fit.
You also need the emitter to focus when the aspheric is in place but DX doesn’t tell you what the back focal length is so you just have to hope that you can make it work.
Depending on your host you may have some adjustment there that you can make (screwing the head in or out).
That said,is there a formula that I can follow to determine ideal bfl,in reference to the emitter type?BTW,I chose the xp-g2 because it’s new and uncharted territory and I’m up for the challenge,not sure if I’m on a fools mission or not.
I just looked up XP-G2. It’s 20% more efficient than XP-G.
It’s not uncharted territory…it’s charted just like all the other emitters.
It won’t throw as far as the XR-E.
There isn’t an ideal bfl. You just have to get the emitter at the right point with regard to the lens. A shorter bfl will give you a larger hotspot and a longer one will give you a smaller hotspot but they will both be the same brightness and will throw the same.
There aren’t that many choices regarding aspherics so you generally buy what you can and hope one of them with have the right bfl for your application.
Well,thanks that makes more sense,and maybe xre is the way to go,I have heard xp-g2 would be more ideal in an aspheric but from what gcbryan said,not as bright.Do you you guys reccommend a certain lens over another for a large thrower?
Cool,thanks!I like that idea too,I have also seen lenses with a.r. coatings on them,is this practical to consider a coated lens or not worth the money?I understand the concept of surface brightness in an aspheric,but I like the xml die for a larger useful beam.edit:spelling sorry
You can always just slightly defocus the aspheric by unscrewing the head for a larger beam and you still have the option for a tight beam by screwing it back in.
It really just depends on what you are looking for regarding throw. If you want the most throw a tightly focus XR-E will give you the most.
If you want a wide beam at the expense of some throw then there are many options.
Cutting dome will only improve the throw for reflector configuration. This is because after de-doming a LED more light will go to the sideway and hits the reflector, thus increasing in throw.
However, since aspherical lens collect lights that emitted out from the front of the LED, de-doming a LED will decrease the throw in this case.
One factor that you are not considering is the apparent surface area of the LED created by LED’s dome. De-doming an LED will decrease the die image size and increases the lux with an aspheric lens. I’ve tried this with both Xm-l and Xr-e LEDS with a gain in lux.
Typically AR coatings will give 5% increase my understanding. My preferred vendor Optolife offers coating on some lenses. Not every aspheric lens offered by them will give good results for flashlight use. I have a 80mm (A142) that seems to have potential but it not listed on the site anymore. I have had good success with their 50mm A293 or A293MC AR coated. Looks like I will give the 75mm lck-led a try.
Yes, the tint is warmer and more yellow. I haven’t used my de-domed Xm-l leds much, but my de-domed Xr-e has been running a about a year and I don’t see any drop in lux.
Is it? I think I saw from somewhere in this forum or other forum (can’t remember anymore) that someone explained this in details.
Note that the LED die surface area is always remain the same no matter you de-dome it or not. The dome is to collect the light emitted from the die and projected them towards a specific direction, kind of acting as an aspherical lens though. But if you de-dome it, the light would become more “scattered” since there is nothing to focus the beam.
But if you said that you have tried it practically and confirmed that you got higeher lux after de-doming the LED (every factors else remain the same), then I don’t know what’s happening behind.
EDIT: Found it, as explained by ma_sha1. You may read the following comments below, though the discussion went a bit ugly in the end…
