Nice review,for how much it costs,not a bad deal.I still haven't got mine yet(blah!!)and I'm eager to mod this sucker.How about the electronic switch,is it as smooth as the real deal?
the multi meter I am using is a craftsman, so fat it has been accurate for what I use it for, it is a shame it did not have last mode memory, the clicky feels solid and very audible, the side switch feels like a Mr. Bulk dragonheart or a solarforce skyline I switch.
hopefully someone can find out how to mod it changing resistors, more pics when it gets dark, Any particular things you all want me to check?
sent from mobile
Alex,
I have one that should be here this week, can you show me a picture of the top after you removed the white centering ring.
Thanx
CAn ST50 3,4A driver from dx can be installed in it?
It seems light is good, but driver is major screw up - what a shame. But at that price, even with new driver this would be good overall price
Are you sure? Veeeery big diff, IMO, after removing ONLY that ring
Thank for the review, Alex
Ok, I’m back home
Pounder, On high there is no PWM, on Med and low there is, it is undetectable by traditional methods (Shaking the light vigorously) but if you put it pointing at a ceiling fan you can barely see it, in regular use you would not notice it.
Rikr, here is a picture of the led with the centering ring removed
Ecig, I think if the resistors in the driver can be tweaked this might be a more powerful light, I’m not an electronics expert, but I sure can solder like one! Need someone to lead the way, It could fit a 1/8 or 1/4 watt resistor with no problems.
SashiX, Don’t be fooled by the camera phone, it tends to over expose bright lights, I had to dial down the brightness of both lights, the Eagletac is brighter on high, but the Small Sun ZY-T13 without the centering ring gives a more concentrated spot, that is the difference, I took another pic, just to make sure which one is which the lights appear on the pic, Eagletac on the left and Small Sun ZY-T13 on the right.
The driver in this light is about 23 - 24 mm and has 2 “ears” that help it keep the side button centered with the side rubber boot.
Any more questions?
AlexGT
When you remove that piece is there any chance the reflector is going to short out by hitting the wires? Can you please take an outside beamshot please.
Thank you for all your time and pictures.
I don’t think the wires can short because the reflector is raised in the center so the edges do not touch the led board, you could always put something to cover them if needed.
Will take pics outside later
Thank you…
I haven’t read this yet, but thanks In advance. I was hoping someone would review this!
On to the reading…
thanks on the PWM…high PWM is acceptable…it looks a lot brighter than the eagletac…looks like it`s on medium…
Both lights were not on high, the Small Sun was on low and the Eagletac was on the second from the lowest setting, the cameraphone tends to exaggerate the contrast, but both beams were about the same brightness but the more concentrated spot tends to look brighter, on high the eagletac is brighter (For now!)
ahhhh makes sense…
Took some pictures outside, the phone’s camera is not very good so you might not notice much difference, someone has to tell me how to do the mouse over thing to compare pics!!! Please!
Distance to the fence 140ft.
Eagletac M3C4 XM-L on Max
Small Sun ZT-T13
Thank you for info and beamshots
doing a mouseover…
-open up the “reply” tab…
-click advanced editor
-put your mouse off image in the url
-click advanced and check the box use alternative image
-put that same url in the “mouse off” box
-put the mouse on link in the “mouse over” box…
save and RELOAD before you give up…I always have to reload before it works…
Thanks Pounder! I will give it a try!
Mouse over attempt #1 Mouse in Small Sun, Mouse out Eagletac, Let me know if it works ok?
works great!
Another thing, The rubber grip comes in two parts a ring and the combat piece, I think that the rubber combat grip and ring needs to be stiffer, this one seems soft compared to surefire’s combat grip, in an emergency if you grip it too hard you might pull it off the flashlight, maybe one of surefire’s rubber grips might fit this light.
