i just don't understand the electronics great stuff Match thank for sharing
[/quote]
That's the beauty of trying a mod like this... The cost is dirt cheap for the learning experience you'll receive. As far as the electronics understanding goes: As long as the positive post on the battery touches the center of the driver board, the negative side of the battery has a path to the outer ring, and the emitter is soldered correctly, it'll work great.
I think this is wonderful! Negligible budget and a great deal of satisfaction about what you've polished. And, let's face it, it keeps one out of mischief.
My first ever mod was a Maglite Solitaire, a bit of dowel, a 12V battery and resistor and a 5mm LED ground down to 3mm.
Pointless, not much use to anyone (Though way more useful than the original) epoxy dust everywhere from grinding down the LED. A nylon brush on a Dremel will polish epoxy nicely back to clear.
But what a sense of achievement - and a great way to stay out of trouble on an otherwise boring evening.
Many of my mods end up involving duct tape - yours are far neater.
That's some really nice work there Match, you've really pushed me into thinking about doing soemthing my self. I used to do metal work and the like, but a lack of access to machines has stopped that...maybe it shouldn't :)
"That's some really nice work there Match, you've really pushed me into thinking about doing soemthing my self. I used to do metal work and the like, but a lack of access to machines has stopped that...maybe it shouldn't "
Exactly as Pook say above , many thanks Match !
I modded a 'Police' one with a 5 modes and a red K2 , too messy to show here , a very crappy job for sure...haha
Yes, as some have commented, Match's work here couldn't even be qualified as a hack, it's just plain good handywork with a bit of engineering and a lot of creativity thrown in. His module is really super clean and tidy, I wish they would sell them like that.
first was an XP-E swap out direct drive with resistor for 14500 OR AA.
second was http://besthongkong.com/product_info.php?cPath=19_63&products_id=526
direct drive. the latter would require no cutting, and greatly increase the output, the first would require the SAME (or similar) mod to match. since im not the first, ill save the XP-E for another flashlight and go with the second lol
Mine are all Blue and purple ..I like the little field and stream delights beam color a 100 times better than the 10 bad ones I got off ebay. i guess I need to buy another 20 or so to find one good one..I was hoping next for a 7119 mxdl ...xml
This kind of mod beats all the expensive lights out there! I love seeing what I can do with as little as possible. The local Dick's has these lights... gonna have to check them out again.
My Ebay Delights don't have a removeable head like this mod by match shows, just the tail switch can be unscrewed. He shows a 'field and stream' box so his must be slightly different? Does the HX-g011 powerlight have both a removeable head and switch?
I like the idea of learning to mod a cheap light, because if you mess it up as a beginner, it's not costing you big bucks.
Anyone think if it's possible to mod something like the powerlight to have the emitter without a reflector put at a 90 angle to the body so it can be used like a headlamp? Like a really cheap 'zebralight' mod.
Yup. It seems to be hit or miss on whether or not the head is removable. It's still possible to mod a fixed head, just a tad more difficult.
As far as making a headlight, I don't know that a powerlight would be the best host for one. I've been meaning to try and make my own, but haven't gotten around to it yet.
